Results 1 to 12 of 12
    Jan 2011
    Default Immo Nissan Patrol GR Y61 2.8td 1998
    Hello i need some help with the immo of this car Nissan Patrol GR Y61 2.8td, because i had damage de eeprom oki m951g trying read as 93c56,and now i need a file with immo off, the ecu is Zexel 407913-148 ref nissan: 23710-vb312 , many thanks for help...
    Jan 2011
    Problem solved, many thanks
    Meat-Head's Avatar
    well upload the solution for the next leecher please
    Jan 2011
    For this ecu zexel i have use this file and work very nice..
  5. The Following 19 Users Say Thank You to GTTURBO2540 For This Useful Post:
    alclot (13th February, 2018), amineben1992 (21st January, 2023), bali motor (1st February, 2014), Electro88 (5th June, 2018), FlaviusBFG (10th December, 2015), haingoben (28th November, 2013), Iron_sim (6th January, 2018), jaelgti (31st May, 2018), jnoroeste (1st June, 2023), julespatch (27th May, 2020), makura (26th July, 2017), MARVAL (1st March, 2021), Meat-Head (6th November, 2013), quimet (23rd November, 2023), Sake (9th May, 2021), thurgau (9th February, 2016), tonyomaki123 (9th November, 2020), xifly18 (12th May, 2015), yordan (31st January, 2020)
  6. #5
    Meat-Head's Avatar
    See, you got a thanks and a like for that, upload with NO password.
    Little things like that help the forum go round.
  7. #6
    DK Veteran haingoben's Avatar
    Dec 2011
    Tana
    just one question;what can I read the nissan eeprom;it's look different?
  8. #7
    Meat-Head's Avatar
    *THINK* use stalk function read/write as 93C46
  9. #8
    Lobster247's Avatar
    Sep 2012
    Belarus. Grodno
    This is a 100% work solutoin without immo?
  10. The Following User Says Thank You to Lobster247 For This Useful Post:
    Gatchet00 (10th December, 2016)
  11. #9
    Top Poster FlaviusBFG's Avatar
    Dec 2011
    Quote Originally Posted by GTTURBO2540 View Post
    Hello !
    M951G OKI Chip ( 93c56 ) on the centre ECU Zexel.
    100% WORK !
    DUMP okird28ti WORK !
    READ / WRITE ONLY 93C56 !!!!!! (forget 93c46) work is 93c56 !!!!!!!
    DISCONNECT IMMO BOX !!!
    FINISH !
    THANKS GTTURBO2540 FOR DUMP !
    w W w . D i g i t a l - K a o s . C o . U k
  12. The Following 12 Users Say Thank You to FlaviusBFG For This Useful Post:
    beltronics (5th June, 2018), cipijoint (24th May, 2019), goosebartek (19th October, 2017), Iron_sim (6th January, 2018), jah83 (30th August, 2016), MARVAL (1st March, 2021), mickye_dj (20th May, 2017), mossa19 (19th February, 2020), oltianmunga (13th June, 2020), qmotors (5th March, 2019), tellfaia (11th April, 2022), thurgau (9th February, 2016)
  13. #10
    Feb 2012
    Dubrovnik
    Quote Originally Posted by FlaviusBFG View Post
    Hello !
    100% WORK !
    FINISH !
    Where is immo box?
    Is the key ring box?
    Thank you
    The best way of being grateful is touching the button thank
  14. #11
    Jul 2010
    Romania
    what model do you have RHD or LHD?
  15. #12
    Jul 2010
    Romania
    i managed to program the M951G chip with the dump okird28ti, the engine started for 2-3 seconds then stopped. it did the same with 93c56 on an ecu from the scrapyard.
    i'we tried with bytes swapped and normal but after three attemps to start the engine , it didn't started for 2-3 sec anymore.
    the mil light is flashing, as it did from the beginning. called nissan dealer and they'we told me the ecu is in lock mode.
    the immo wire was cut from the beginning .
    is there a procedure to reset the ecu from lock mode?
    forget lock mode, this morning i shipped the car to nissan dealer, and they resync the key with the car immo(i have only one key) and the engine is starting now.
    if someone needs the dump from the working ecu i can send it if i can get some help with immo off.
    i need immo off because i use the car for offroad only and i want to relocate ecu and some of the electronics wich can get wet if the car get's flooded,
    i'm also trying to tune the ecu so i can get more fuel into the engine because i upgraded the turbo i now i need more fuel as the volume of air increased, and have another spare ecu if this one fails in the process but withouth going to nissan dealer for resync
    please help me with immo off
