Page 33 of 37 FirstFirst ... 2328293031323334353637 LastLast
Results 481 to 495 of 553
  1. #481
    auto techniek's Avatar
    Mar 2017
    Sure. I m waiting for condor mini plus soon.
    Seems a better choice.
  2. The Following User Says Thank You to auto techniek For This Useful Post:
    szengen (7th June, 2018)
  3. #482
    Feb 2017
    UK
    does anyone have experience cutting hu49 the blade for old Vag cars. I just noticed that there are 2 settings and the length, width is different. Can someone explain how to recognize which one is witch? I have only beating code and make model Golf MK3. Please see attached picture for reference.
  4. #483
    Feb 2010
    Essex/East London Boarder
    I belive the last one i did was 246 in description on A5
    I just pulled the plug and put in a blank and guesteimated the cut .
    I know what you mean about spacing its to do with double wafer in chambers ?.
  5. The Following User Says Thank You to Recoder For This Useful Post:
    redliner (15th June, 2018)
  6. #484
    Feb 2017
    UK
    Quote Originally Posted by Recoder View Post
    don't know realy which one is the proper cut for Golf MK3 or how to recognize which type should be used as instacode show both in the same make model and year of manufacture. I can't cut and try as this is work by postage.
    Those 2 types are different from cutting a bit. Look into my previous picture from Instacode. It can be seen that first 3 pins are the same length and the rest is moved a bit.
  7. #485
    Feb 2017
    UK
    Quote Originally Posted by ibratex View Post
    hello mates how to use x6 v8 to cut hu101 rover key please guide me any video oit there thanks in advance
    Sent from my SM-G935F using Tapatalk
    This is the same as Ford Hu101 and I cutting normally both sides using software and then measure difference by caliper on each spot and doing code adjustment. Long time - 2 or 3 time must cut for accurate measure.
  8. #486
    Feb 2017
    UK
    Quote Originally Posted by darknezz19 View Post
    Mine did the same thing yesterday. Cut a test key and it worked great, then when trying to cut the flip key blade it offset lower just like yours. I didn't use the HU66 adapter but will try again with it today.
    Hi Guys I noticed the same thing with my machine. It's because the tip has sharp edges and it's more cutted then original blade.(It can be seen on yours pictured) I don't know how to set up machine to adjust this as my machine cut like this from beginning. Some of the key stuck in the lock but if you soften the edges it will work.
  9. #487
    Jun 2017
    US
    Just replaced all the belts on mine. Order a replacement pack from a website a while back but only like 2 of the 5 were correct. Anyway belt list for X6 V8 if anyone needs.
    B64MXL Cutter Belt
    63MXL X Axis Belt 1
    B153MXL X Axis Belt 2
    B94MXL Y Axis Belt 1
    B78MXL Y Axis Belt 2
  10. #488
    hcip's Avatar
    Dec 2009
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    How to add key profile in this machine....
    https://www.youtube.com/watch?v=iyP0AEHf-qA
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  11. The Following 5 Users Say Thank You to hcip For This Useful Post:
    81zx (1st October, 2018), H.Wessel (1st October, 2018), Krittanu (11th January, 2019), lock66 (21st September, 2018), obeids (7th October, 2018)
  12. #489
    hcip's Avatar
    Dec 2009
    anybody has a key measurement of Toyota Wigo on Instacode?
    Can you shre it to me?
    Thanks in advance
  13. #490
    Oct 2017
    X6v8 best ever no problems yet. Easy to work on yourself. And easy to work
  14. #491
    Oct 2018
    Europe
    Can anyone say where is the best place to buy a x6 v8 machine from? and also is there an "updated" latest version of this machine that has a direct drive motor instead of belt driven? or is there such a thing?
    Thanks in advance for any help.
  15. #492
    May 2013
    Quote Originally Posted by Brof View Post
    The newer ones were all direct drive motors. However these direct drive motors gave me some trouble. Either motors were faulty or some had faulty speed controller boards....
  16. #493
    super jumbe's Avatar
    Dec 2008
    Livingstone
    Can X6/V8 able to cut ford tibbi cuts?
  17. #494
    Top Poster ramiz auto lock's Avatar
    Nov 2017
    NORTH LONDON
    Quote Originally Posted by super jumbe View Post
    Yes but you need fo21 adopter
    Sent from my SM-G925F using Tapatalk
  18. The Following User Says Thank You to ramiz auto lock For This Useful Post:
    super jumbe (4th November, 2018)
  19. #495
    Nov 2015
    UK
    Yes it can.
    Fo21 adapter is about £25 from China and is easy to use.
  20. The Following User Says Thank You to Buddy41 For This Useful Post:
