Page 1 of 2 12 LastLast
Results 1 to 15 of 19
    May 2011
    Default Please clear Ford Ranger (Infineon chip)
    Hi people can someone please try to clear my ford ranger file? it is also read from infineon X2060 chip.
    Module: AB39-14B321-CE
    May 2011
    sorry i dont mean to be a irritation but does anybody have a solution?
    Nov 2009
    Minsk, Belarus
    Try its, and You need clear fault of scaner. And pls write full name of MCU: XC2060-?? (XC2060-40 for example). And post full damp, if You can read its
    As all times: no result, no answer
    Mar 2014
    Poland
    try and report
    should be all ok
    pass in pm
    Jan 2010
    [Please help for same airbag ECU AB39-14B321-CE
    Jun 2012
    Brasil
    Default RANGER
    test and report
    pass pm
  7. The Following User Says Thank You to apolo2100 For This Useful Post:
    matej12 (1st December, 2015)
  8. #7
    Jan 2010
    Thank you, next day tested nand report
  9. #8
    Jan 2010
    Super, work ok. Thanks verry much
  10. #9
    autocargo's Avatar
    Hello I've got the same airbag ecu AB39-14B321-CE Never done this one before... Can someone please help me clear crash data?
    Thanks on advance.
  11. #10
    Top Poster + cristi_onofrei's Avatar
    Nov 2009
    Iasi, Romania
    Hello!
    Can somebody help me to clear this airbag?
    Thank you!
    Cristi
    SOLVED
  12. #11
    pedjica's Avatar
    Sep 2015
    Serbia
    Please try to clear my ford ranger file.
    AB39-14B321-CE FORD RANGER
    If I helped, please, use magic buttons reputation+thanks.
  13. #12
    slick_dick's Avatar
    Dec 2009
    Essex
    Your file cleared
    test and report
    regards
    slick
  14. The Following User Says Thank You to slick_dick For This Useful Post:
    pedjica (29th May, 2018)
  15. #13
    hexguru's Avatar
    Nov 2016
    He wrote that the problem is already solved
  16. #14
    pedjica's Avatar
    Sep 2015
    Serbia
    not work b1193 crash event storage
  17. #15
    hexguru's Avatar
    Nov 2016
    try this pass pm
  18. The Following User Says Thank You to hexguru For This Useful Post:
