f21 (5th February, 2021), Faraday (28th January, 2015), karter1 (1st November, 2019), obdsystems (12th August, 2015), u.s (15th June, 2014)
could you calc CS and Pin out of this dump?
thnx in advance
comfort95320.rar
Login: 22773
VIN: WVWZZZ3CZ7P003912
seal777 (1st March, 2020)
thnx ,but that can be done with AVDI. I really need CS for adaption.
CS : D2 9C D6 57 A5 39 AC
Bishop c4 (14th September, 2014), cammy25 (26th July, 2014), cjawahir (26th July, 2014), easternghost (9th October, 2014), Fallen (26th July, 2014), gepakg (26th July, 2014), keysph (26th July, 2014), pezao (9th October, 2014), PremierD (26th July, 2014), triak88 (15th September, 2014), vlado kljucar (26th July, 2014)
I can only confirm that is correct![]()
I need pin and CS
No army may enter that land
That is protected by polish hand
Unless you are 40 to 1
Your force will soon be undone
digikeys (13th February, 2024)
PIN: 15114
Component Security Bytes: 2B A4 EF B0 57 49 DF
Bishop c4 (14th September, 2014), bugajewski_pl (13th September, 2014), Faraday (13th October, 2014)
thanks guys, pin and CS are correct.
Hello I need please PIN/VIN /CS from this passat confort module.
PASSAT 2007
3C0959433
SW 0434 HW 038
HELLA W42 21/03/05 P004-1226
5DK 009 064-00
EEPROM 95320
I have error 0003 control module defective, It can be solved with Odis by flashing, but I want to have all data beforemake something wrong. Car now is crancking with all keys, but sometimes gets error and dont cranck.
Thanks beforehand
Elektrik001 (19th September, 2019)
VIN: WVWZZZ3CZ6E024119
PIN: 43938
Component Security Bytes: 84 C9 8A 35 09 93 14
There you go mate ....![]()
GolfmkI (9th October, 2014)
GolfmkI (10th October, 2014)
Thanks PremierD!!!
It is working perfect!!!
Autofan1965 I prefer the Odis procedure, I have just done.
Flash was about 6 minutes, and this way you dont need any donor unit, you simply repair original.
Car is working perfect now!!
Odis could repair lot of units that have tipycal error 00003 defective and so on..
Its a bit risky sometimes, but when you use it theres not so many other choices.
Elektrik001 (19th September, 2019), HeXeN (11th April, 2015)
Passat CS + PIN.rar
hi got another that I can not read the pin yet, can anyone help with CS and PIN
thanks zip
willyboy28 (15th April, 2018)
