Page 12 of 21 FirstFirst ... 27891011121314151617 ... LastLast
Results 166 to 180 of 303
  1. #166
    Dec 2009
    I have the problem of pressure sensor, can you tell me how to fix it ??? Thank you
  2. #167
    Sep 2015
    Hello guys,
    I have one MK26 Chrysler voyager 2007 with no communication.
    What can be the problem ?
    Regards,
  3. #168
    Oct 2014
    romania
    What should i do on a abs pump laguna2 df185 error
  4. #169
    soxten's Avatar
    Mar 2013
    Need help how to fix 4F0910517K with pressure sensor fault.
    And this type is Bosch ABS 8.0 system and have a plastic brake pressure sensor on alu.block (not metall pressure sensor as the normal fault G201)
    Fult is 01435 Brake pressure sensor 1 Activ.
    need help how to find a way to repair this ecu.
  5. #170
    Jun 2010
    Whats the best way to solder aluwires on BMW DSC ecu? And anyone got solution how to replace those golden ones?
  6. #171
    soxten's Avatar
    Mar 2013
    Quote Originally Posted by ptikkala View Post
    For Alu.wire use solder flush special for aluminum.
    Gold wire, does not get broken, dont touch them!
    Skickat från min iPhone med Tapatalk
  7. #172
    Jun 2010
    Can you recommend any particular flush?
  8. #173
    Dec 2014
    Default i need abs 207 peugeot no communication
    peugeot 207 abs ı check power 12 v ok gnd ok acc ok can ok but no communication
    ı try difrent abs module communication ok
    ı try resolder big pın problem same ı uplated pictures how is repair
  9. #174
    Sep 2015
    Hello I have here a Mk25 volvo abs 2002
    I need to connect it on bench.
    Can somebody help me ?
    8671224
    Do i need to connect CEM also because if i use can wires now directly to obd from scan tool No COMM.
  10. #175
    Feb 2011
    Dear Member of digital Kaos,
    I spent 2 years months working on the subject.
    I searched the pressure sensor...
    I have sent on ACTRONICS my ABS ATE MK60 with an error of pressure sensor.
    See the picture
    the steel tube is cut.
    Sorry for my english
  11. #176
    Feb 2011
  12. The Following User Says Thank You to papyrusse For This Useful Post:
    Rollaass (22nd August, 2022)
  13. #177
    Feb 2011
    the pressure sensor is repaired or change?
  14. #178
    soxten's Avatar
    Mar 2013
    Here is info to ALL how to take away metall cover on Pressure sensor.
    After you done this all 4 wire is lose on upper pcb under the gel.
    If you solder it back on pcb you get problem after!
    It is not working 100%
    If some one find a way to solder it back, PLEASE SHARE!
    First remove label on pressure sensor!
    I put my tool in sideway to sideway in small movements, left to right and here the "click"
    Then take tool away!
    Take a small screwdriver and push black connector THEN lift steel tube up!
    Importen! Push black connector down then lift steel tube!!!!!
    Then open up the sensor by lift 2 small steel plate on side.
    Next way is to find a safe way to repair it.
    Normaly use wirebonding after cleaning gel out.
    Please push tanks if it help you
  15. The Following 16 Users Say Thank You to soxten For This Useful Post:
    boujou (10th March, 2021), DSAuto (15th October, 2018), dsz (12th September, 2018), Eddie034 (3rd December, 2017), evisdaci (25th September, 2023), g5n14 (23rd May, 2019), kelpe (18th December, 2020), kwat (13th January, 2024), makaronar (17th January, 2018), mexanico1971 (18th April, 2018), oiknikos (4th March, 2020), papyrusse (24th November, 2017), rochinha75 (3rd March, 2021), SvenR1 (13th March, 2018), TeiS (8th December, 2022), vertyk (11th July, 2023)
  16. #179
    Feb 2011
    Thanks for your post soxten.
    What's your tool?
    Please, give me a link on google
  17. #180
    Feb 2011
    the pressure sensor is a brand "BOSCH"?
