Results 1 to 15 of 15
    Dec 2011
    Nottingham
    Default Mazda 3 Radio Code 24C02
    Hi all, could someone help with code for Sanyo Mazda 3 code. Numbers on radio are:
    14794018
    BR2D66AR0
    24C02 dump attached
  2. The Following User Says Thank You to Autowave For This Useful Post:
    csavargo2 (30th November, 2016)
  3. #2
    Dec 2009
    try code 3077 ????
    Dec 2011
    Nottingham
    3077 didn't work I'm afraid. Anything else?
    Jul 2010
    Bulgaria
    Try code ​3141
  6. The Following 6 Users Say Thank You to bogege For This Useful Post:
    arık (9th September, 2014), Autowave (11th September, 2014), csavargo2 (30th November, 2016), masterskay62 (9th September, 2014), nelutzul40 (10th September, 2014), smoggy (9th September, 2014)
  7. #5
    Dec 2009
    yes misread
    the correct code 3141
  8. The Following 4 Users Say Thank You to arık For This Useful Post:
    Autowave (11th September, 2014), bogege (9th September, 2014), csavargo2 (30th November, 2016), smoggy (9th September, 2014)
  9. #6
    Dec 2011
    Nottingham
    thanks, worked a treat
  10. The Following User Says Thank You to Autowave For This Useful Post:
    arık (12th September, 2014)
  11. #7
    Feb 2013
    UK Bristol
    Hi folks.
    Can someone be help with My Radio Code, i need know PIn Code from ther same radio what is Topic
  12. #8
    richiebb's Avatar
    Aug 2015
    Argentina
    Quote Originally Posted by pocinas View Post
    Hi folks.
    code is 7917
  13. The Following 6 Users Say Thank You to richiebb For This Useful Post:
    bogege (13th October, 2018), Decode Ghost (16th October, 2018), irfa (13th October, 2018), masterskay62 (13th October, 2018), shooting (13th October, 2018), smoggy (13th October, 2018)
  14. #9
    Feb 2013
    UK Bristol
    Quote Originally Posted by richiebb View Post
    code is 7917
    thanks a lot.
    it is any chance switch off or reset counter wrong attempt? Customer said cant write code, waintg couple od hours with switch on ignition but doesnt work.
    P.S can i know how you generate pin code from eeprom dump?
  15. #10
    richiebb's Avatar
    Aug 2015
    Argentina
    thanks a lot.
    not sure.......... try this file
  16. The Following User Says Thank You to richiebb For This Useful Post:
    pocinas (17th October, 2018)
  17. #11
    Feb 2013
    UK Bristol
    I not try you file yet but... i found procedures keys to write code which is
    6, AM, AUTO M and seek up. Then i provide 4 digit code 7917. And confirmed press 2 buttons together AUTO M and 6. After second is just Beeep and error again...
    It is possible be was diffrent code?, chip on the mainboard looks like genuine solder, so was not touched.
    What is wierd customer found card with code to radio which is exacly the same what you generated 7917 But doesnt work.
    Any ideas what can be heappends or maybe diffrent code...
    My post helps you? Please Hit Buttons
  18. #12
    Jul 2010
    Bulgaria
    Please note that code entry is only possible with the ignition switched on, and in the order shown. If the display continually shows "ERR" then the unit may be codelocked and all of your code entry attempts may have been used up.
    Try this.....................
    Code Entry as Follows:
    Switch ON the Ignition (No need to start car)
    Switch Radio On - Display Shows
    " COdE " Flashing
    Press And Hold " Auto-M " And Preset " 6 "
    The Display Will Show " - - - - "
    Press preset " 1 " repeatedly for 1st Digit
    Press preset " 2 " repeatedly for 2nd Digit
    Press preset " 3 " repeatedly for 3rd Digit
    Press preset " 4 " repeatedly for 4th Digit
    If the correct code number is now shown
    The Display Will Slowly Flash "CODE"
    And the Radio will then Turn On
  19. The Following 2 Users Say Thank You to bogege For This Useful Post:
    Decode Ghost (16th October, 2018), shooting (15th October, 2018)
  20. #13
    Feb 2013
    UK Bristol
    The situation is little diffrent.
    When i turn ignition on , then on the screen blinking ERR
    when i press 6, AM, Auto M and finally Seek up then ERR is changed to "----" But got arround 20 sec to. starting provide code, if not start than ---- is changed again to ERR. The same is when i provide code but not accept code, than from code changing to Blinking ERR.
    Radio never shows CODE. just ERR or ----
    ''code entry attempts may have been used up''
    Who know... i tried write code like 15...20 times.
    How i can reset entry attempts?
  21. #14
    Jul 2010
    Bulgaria
    try dump from member richiebb
  22. The Following 2 Users Say Thank You to bogege For This Useful Post:
    Decode Ghost (16th October, 2018), richiebb (17th October, 2018)
  23. #15
    Feb 2013
    UK Bristol
    Quote Originally Posted by bogege View Post
    I would like say.. BIG THANKS A LOT
    after flash file with reset counter radio works perfect
  24. The Following 2 Users Say Thank You to pocinas For This Useful Post:
    bogege (18th October, 2018), richiebb (17th October, 2018)
