Results 1 to 11 of 11
    Mar 2014
    Philippines
    Question Chevrolet Aveo Dashboard Disassembly
    Can somebody guides me on how to safely disassemble this dash Chevrolet Aveo 2009. I'm stuck at the LCD removal.
    TIA
    hacko12's Avatar
    Mar 2010
    Try to remove white plastic not lcd display.
    If I helped you, you may use thanks and reputation button on my post. Thank you!
    Mar 2014
    Philippines
    Quote Originally Posted by hacko12 View Post
    Impossible..because the white plastic is "SANDWICH" between the LCD and the PCB.
    Jan 2010
    uk
    you have to de solder lcd to get to pcb..
  5. The Following User Says Thank You to raf0468 For This Useful Post:
    kasamiko (2nd December, 2014)
  6. #5
    Mar 2014
    Philippines
    @raf0468
    Is it safe to desolder the LCD? does this terminal directly connects to the LCD glass?
  7. #6
    drpeter's Avatar
    Dec 2009
    The Netherlands
    Quote Originally Posted by kasamiko View Post
    @raf0468
    It is safe to desolder but normally the lcd is connected in a onboard socket. Don't sure about aveo though.
  8. #7
    Mar 2014
    Philippines
    Quote Originally Posted by drpeter View Post
    Hi drpeter,
    Yes mostly I encountered LCD modules are "socketed" I tried lifting gently this one but it seems the LCD is soldered in place. I also tried desoldering few pins but the pins seems to as if melted below so I stop.
  9. #8
    claudio35's Avatar
    Dec 2009
    Chile
    Aveo c56........The images are not mine, I have no more information
  10. The Following 6 Users Say Thank You to claudio35 For This Useful Post:
    a2000 (3rd December, 2014), boxsport (17th December, 2020), DAVID8HENRY8 (4th September, 2017), kasamiko (2nd December, 2014), mawar (2nd December, 2014), pongsky (9th March, 2015)
  11. #9
    Nov 2011
    Macedonia
    Default I confirm
    I confirm post claudio35 with my pictures
    Baze007
  12. The Following 5 Users Say Thank You to baze007 For This Useful Post:
    abuuauto (6th December, 2014), boxsport (17th December, 2020), DAVID8HENRY8 (4th September, 2017), kasamiko (5th December, 2014), pongsky (9th March, 2015)
  13. #10
    May 2013
    that is the best way, I have two dashboard with broken display, it?s very easy to break
  14. #11
    Mar 2014
    Philippines
    Thumbs up
    Done with your help guys!
