Page 27 of 48 FirstFirst ... 17222324252627282930313237 ... LastLast
Results 391 to 405 of 720
  1. #391
    gopelhu's Avatar
    Jan 2010
    EU
    Quote Originally Posted by mrchip View Post
    which PCB version is better ?
    this one ???
    Attachment 484609
    or this one ?
    Attachment 484610
    as the same but the v4-1 is a dongle version without online and v6-1 is a softdog version with online function.
    Regards, G
  2. The Following User Says Thank You to gopelhu For This Useful Post:
    mrchip (26th November, 2017)
  3. #392
    Jan 2016
    Quote Originally Posted by gopelhu View Post
    Regards, G
    Thanks for answer
    I read also on other forums that version 2014 is better then 2015,,
    can somebody share an link for 2014 stable version ? does matter with or without online functions?? ( I mean which one is more stable )
    what is the difference between softdog and dongle ? both looks same
  4. #393
    Apr 2017
    RS - Brazil
    I need calculate long code of vw airbag cars... Avdi clone can make this? I hear about vcds can make,but only online... Anyone know about?
    Enviado de meu SM-G920I usando Tapatalk
  5. #394
    gopelhu's Avatar
    Jan 2010
    EU
    Thanks for answer
    Hi again,
    dongle and softdog not a same !!!! pls check the attachment.
    all fvdi with softdog version are online versions
    I recommended the dongle v2013 or v2014 version without online version.
    Regards, G
  6. #395
    Dec 2014
    Hello friends. Will anyone repair FVDI 2015 (CHINA) ??? After connecting the USB there is no reaction ... the FVDI does not turn on the led ...
  7. #396
    Jun 2010
    Romania
    Default fly fvdi ?
    Hello. Is this fvdi from fly ? I tried today to remove seat mat from a BMW E90 and could not do it. Not from the button, and not from coding. When I want to read coding it sais that it could not read coding or wrong chassis selected. Tried with 1 series, 3 series...
  8. #397
    gopelhu's Avatar
    Jan 2010
    EU
    Quote Originally Posted by Fliper85 View Post
    write me a pm and tell me all infos....
    Regards, G
  9. The Following User Says Thank You to gopelhu For This Useful Post:
    Stelaras26 (29th December, 2017)
  10. #398
    gopelhu's Avatar
    Jan 2010
    EU
    Quote Originally Posted by vyoinlove View Post
    hmmmmmmmmmmmmmmm.............. thats interesting, bec your fvdi orig fly company product without softdog version.
    Firstly, pls contact with Miller from fly company, maybe he will help you.
    Regards, G
  11. #399
    Jun 2010
    Romania
    Thank you for the reply. I have tried again and it worked. Strange that it would not work in the first time.
  12. The Following User Says Thank You to vyoinlove For This Useful Post:
    gopelhu (28th December, 2017)
  13. #400
    Dec 2012
    Hi Gopelhu, i wrecked my fvdi with reading a Toyota avensis with 4A-FE engine. Pin 9 got the full load of high voltage from the dlc connector of the car and now the fvdi is dead. i replaced the lpc1788 and lots of other components on the board an needs new programming of the lpc now, and the solide state relay K4 in the picture is leading to knowhere on the board, atleast i couldend find it maybe you can tell me to where the pin goos?
  14. #401
    Jan 2016
    Hi,K-line fixing it with ADG1406BRUZ and ADG1404YRUZ and K-line ic L9637D.Regards, G
    Hi Gopelhu
    I have some questions:
    1-I have allready ADG1406BRUZ and L9637D on board ( from factory) but cant connect any old car with K-Line ( pls see pics), or need I to order Original ADG1406BRUZ and L9637D ?
    2- need I replace also my mof relays if so by which one ?
    3-
    my intention was to buy a fvdi that 2014 without online funtion because everyone says ( You too ) that this version is the best ,, I am now cheated or this is the correct version?
    what do you think about my fvdi? my pcb is not the same as it is described on the ad, seller has changed the pictures when I said it is not fair.
    need I to replace more parts ?
    thanks for your time
  15. #402
    Newbie maiser91's Avatar
    Nov 2014
    Paris dans le 91
    Unhappy
    [QUOTE = gopelhu; 3037554] Salut à tous,
    2ans 3 mois 6 jours ...... très très longtemps ......
    mais j'ai fini de résoudre tous les fwgenerator v34 & v36 .....
    seulement pour vous faire connaître ces infos .....
    Cordialement, G [/ QUOTE]
    Bonjour, j'ai bloqué mon interface Fvdi V4-1 complète J'ai le led rouge clignotant depuis la mise à jour vous pouvez m'aider s'il vous plaît résoudre le problème
  16. #403
    Nov 2014
    Paris dans le 91
    Hello, I blocked my interface Fvdi V4-1 complete I have the red led flashing since the update you can help me please solve the problem
  17. #404
    melcool's Avatar
    Nov 2009
    SPACE
    Hi!
    My interface FlyFVDI 2014 no dongle/softdog - very good clone
    I have the same problem with the same car Toyota Avensis with 4A-FE engine
    this car can DESTROY any diagnostic with un-proper OBD leads
    PLEASE BE AWARE to all users
    -NXP LPC1788 is damaged very HOT with 5+USB in)
    -multiplexers damaged part U10 U13
    I have contacted Fly company and thy give me link to download and program by usb fw.bin wf.bin and db.bin but not work by usb
    i need help to program LPC by uart for new LPC1788 installed
    FVDI unit
    F00316
    046001032294BCAE3E230A56C21C00F5
    i have fw.bin wf.bin and db.bin they told me to not give to anywone )))
  18. The Following 14 Users Say Thank You to melcool For This Useful Post:
    carcode (9th January, 2021), Col19 (8th December, 2020), estwood68 (9th January, 2020), gopelhu (28th January, 2018), guliver21 (18th May, 2020), just4upal (24th January, 2018), mickye_dj (8th September, 2018), Msmax (20th July, 2023), NONO59 (4th December, 2023), Rachon (13th February, 2018), Stelaras26 (7th February, 2018), Talleresmalaga (2nd May, 2020), vari (26th June, 2018), xseva (15th December, 2018)
  19. #405
    Dec 2014
    Lithuania
    Quote Originally Posted by melcool View Post
    Hi!
    could you share the link?I'll try to experiment
