Mobile at the time and have no dump
EPROM is atmel 93c66 located in the left of label
Cut PVC 2x2 cm
Sent from my Optimus 4X HD using Tapatalk
hi there
got a bike that has keys but something is wrong with ecu, so customer got another one, could I just swop immo chip across from original one to 2nd hand one, haven't opened ecu yet, does this ecu have a 93c66 or a 24so2 I must took for , does anyone have an idea where chip is about ? or would I need the dump to be reset to work, any advice would be greatly appreciated
all the best
Cut PVC 2x2 cm
raptureready (26th February, 2015)
The 01 ecu is update version of the 00 that have many problems in throttle hesitation and on-off feeling.
Eeprom is atmel 93c66a .
You can disable immobilizer from the rom flash if you know how to do it.
could I just swop the 93c66a on the ecu or wont that work?
thanks so much for help
kind regards
Yes that will work
post dump of donor ecu
Professional BMW immo solutions
Macedonia is one and GREEK!!!
raptureready (27th February, 2015)
hello all dk its possible syncron ecu and immobox data on yamaha fz6
