Results 1 to 12 of 12
Threaded View
    Top Poster weedman's Avatar
    Dec 2011
    By my computer
    Default How to debug CrossEPG issues and get it working on OpenPLi 4
    This is a guide to help you guys who are struggling to get CrossEPG working on OpenPLi 4. I've reinstalled and configured the same image many times and I've gotten CrossEPG working everytime, below i'll show you how.
    Install libcurl4 - This should fix all the issues
    It's actually just 1 library thats missing `libcurl4`, install it using:
    opkg install libcurl4
    You may need to reboot (although I don't think it's necessary).
    Go back to CrossEPG, make sure it's set to write to your HDD or USB, select Sky UK from the providers list and hit Download.. tada!
    Still not working?
    If it's still not working you'll have to do some debugging (It's actually quite easy), run the following command through telnet.
    init 4; sleep 4; enigma2;
    This will reboot your dreambox and you'll see all the debugging output logged to your console. Go back and try the CrossEPG download, when it fails keep an eye on the logging info and see what it says.
    This was how I debugged the `libcurl4` issue!
    Hopefully this helps all you guys having issues with CrossEPG, not sure about other images but this 100% works on OpenPLi 4.
    The debugging technique should aid you in tracking down any issues your having (relating to CrossEPG or anything else - It's extremely useful to see all the debugging when something goes wrong).
    - Thanks to those who deserve them, and none to those who don't...
    - DM 800 HD - Clone | DM 800 HD SE - Clone | Openbox S11
    - weedman
  2. The Following 4 Users Say Thank You to weedman For This Useful Post:
    gmb45 (7th March, 2015), martialdiego (1st August, 2015), Slots (6th February, 2016), sumfeen (10th January, 2016)
