Page 1 of 2 12 LastLast
Results 1 to 15 of 28
    nigrou's Avatar
    Dec 2010
    algeria mascara
    Default rcd 210 panasonic
    salam
    plz help code and safe2 rcd 210 panasonic
    serier:014vwz5z1h00300787
    1k0 035 156 a
    I know very well that is not code in the eprom
    But Sally programmed to read m32c
    Is there another solution device
    Thank you
    "Stop racism, for we are all human beings"
    audiopoint's Avatar
    Mar 2011
    MACEDONIA
    http://www.digital-kaos.co.uk/forums...=1#post2143473
    try solution without code for RCD500 maybe work on rcd210
  3. The Following 3 Users Say Thank You to audiopoint For This Useful Post:
    kappa1 (15th March, 2015), nigrou (12th March, 2015), REZON (6th May, 2015)
    nigrou's Avatar
    Dec 2010
    algeria mascara
    [QUOTE=audiopoint;2490574] http://www.digital-kaos.co.uk/forums...=1#post2143473
    try code sans solution verser RCD500 Fonctionne Peut-etre sur rcd210 [/ QUOTE] Ce lien ne fonctionne pas, il se ouvre une page avec l'erreur 404 o
    posible reset couter
    nigrou's Avatar
    Dec 2010
    algeria mascara
    solved code 0025
    I find the method to decode rcd210 panasonic
    was ready two days
  6. The Following 7 Users Say Thank You to nigrou For This Useful Post:
    bogege (14th March, 2015), kappa1 (29th December, 2015), masterskay62 (14th March, 2015), murat332 (14th March, 2015), nelutzul40 (14th March, 2015), REZON (6th May, 2015), smoggy (14th March, 2015)
  7. #5
    Jan 2010
    K.Kambelovac Croatia
    with which programer you read mcu
  8. #6
    iProg-carradio
    Guest
    Quote Originally Posted by mlulic View Post
    code in MCU
    MCU = M30879FKAJP
    programmer = M16C Flasher
  9. #7
    skens's Avatar
    Mar 2010
    Zagreb,Croatia
    hi
    i downlaod M16C flasher!
    how to connect to the serial port on the MCU?
    of which position is hidden cod?
    regards
    Please dear members push the button thanks and reputation button(stars)
    do you need help? fill it in !!!
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    ECU type and number:
    Memories :
    https://www.digital-kaos.co.uk/forum...63#post1660863
  10. #8
    kappa1's Avatar
    Apr 2013
    RO-IS
    Quote Originally Posted by skens View Post
    hi
    regards
    Try this conection: http://help.martech.pl/?q=node/41
  11. The Following 3 Users Say Thank You to kappa1 For This Useful Post:
    Decode Ghost (21st July, 2017), mcd76 (4th September, 2015), skens (3rd September, 2015)
  12. #9
    skens's Avatar
    Mar 2010
    Zagreb,Croatia
    hi
    M16C flasher
    connect to the direct serial port DB9 or DB25 LTP on the MCU!
    not need interface?
    regards
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    Memories :
  13. #10
    Sep 2009
    Romania
    You need interface of course.In picture is the martech adaptor DB25 not direct LTP port.This adaptor conect to the martech box.And martech read this m32c.
    Also i tried with rs232 interface but not conect to this M32c, only conect to RCD500 m32c flash.Maybe somebody has a solution.
    Also have solution to loked the counter but in this way takes more time to find code.
  14. The Following 3 Users Say Thank You to attilaa0 For This Useful Post:
    clydey (8th September, 2015), Decode Ghost (21st July, 2017), mcd76 (4th September, 2015)
  15. #11
    skens's Avatar
    Mar 2010
    Zagreb,Croatia
    hi
    ihttp://www.m16c-flasher.de/
    please read
    There is no extra hardware required. The only thing you need is a serial cable between pc and microcontroller...
    regards
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    Memories :
  16. The Following User Says Thank You to skens For This Useful Post:
    XJTAG (13th December, 2019)
  17. #12
    Sep 2009
    Romania
    Yes !You are right but it can read only M30833 from rcd500 panasonic.For rcd210 you must read M30879 which can not support this flasher.
  18. The Following User Says Thank You to attilaa0 For This Useful Post:
    skens (5th September, 2015)
  19. #13
    Quote Originally Posted by attilaa0 View Post
    Hello man.
    Help please!
    Can you share the conections you used to read m30833 from rcd500 mp3?
    regards
  20. #14
    sonices's Avatar
    Jul 2010
    These are connections
  21. The Following User Says Thank You to sonices For This Useful Post:
  22. #15
    Hello.
    Thanks for aswering.
    Acording to the picture attached how should be the correspondent connections made?
    regards
