Hello, I need to reset the airbag on a 2010 Skoda Fabia, and I want to buy to do it myself. But I'm in a mess.What do you recommend? Carprog 8.21, 10.93, 13.77... o Carprog 2, or better upa usb programmer...Thank you so much
Online functions don't work in Carprog 13.77 When I try to use them I receive error " CAN`T CONNECT TO REMOTE SERVER". Annyone with same issue? It should work in every 13.77 version?
Online in 13.77 does not work, 8.21 used a "fake" server, while 13.77 does not use it
carradio2001 (9th May, 2024)
Have you got 13.77 version? As far as I know online functions should work in 8.21 version
Yes, I have versions 13.77 and 8.21 but, like yours, 13.77 does not connect to the server, 8.21 works on a "fake" server and online works.
13.77 version is really useless. I think that its firmware can be downgraded to 8.21 version. Will you try to do it?
I use 8.21 with firmware from 13.77, I just copied the .lib file from 13.77 to the 8.21 folder and it works normally for me, I didn't downgrade the firmware
I've already tried that, all offline functions worked normaly as in 13.77 version but when I used online functions it couldn't establish communication with car although online function worked. That issuse should be related to device firmware which must be downgraded and use .lib file from real 8.21 version
need that pass pls
