(VV-03)VAG prepare dealer key by ECU data
What cars does this work on?
How does it work?
Screenshots/Manual?
How does it work?
Screenshots/Manual?
drugowaz (23rd September, 2017)
Is there any possibility to add key to BMW program using file key read before by diagnostic (file generated when you connect to car) without having car? I have a car far away from me and this would be a good software update to make a key and send to customer the key already made.
@louis21
Enviado desde mi SM-G955F mediante Tapatalk
BMW 868Mhz remote renew. Tested after renew and reprogramed to my car for testing purposes. Works great. Is not affordable instead new remotes prices, but it's good to know it can do it...
Just search : how to open vvdi2 id48 transponder key chip copy functions
But this function is useless in EDC17 OBD , since they never fix problem Read CS, MAC and Pin on EDC17 via OBD. Only can be use in MED17.
Main purpose is to add key in All lost situation with out remove dash out, all OBD, or new dash after 06-2014 add key , But since SMOK and other companies now can do dash after 6-2014 this function can be use only in All lost key with MED17 only.
@hipolitogt @Louis21
Vvdi BUG. in Autodetect transponder
excuse my English, is the best.
its not bug. its chinese keys games.
I have pcf7941 marking . when scanned shows 7945. chinese play with id
yugo45 (24th September, 2017)
lidons (24th September, 2017)
Audi A4 RB4 crypto read immodata good but for dash change when write immodata it say ONLY VIN will be written to dash... So I must use other tool to finish job. In RB8 is the same ??
drugowaz (24th September, 2017)
Yes, you can adapt with everything you want. With vvdi2 for example to make it with RB4
1- you have to know 2 pin, original from car, and donor one. Example: 1234 and 4321
2- enter instruments with donor installed. Enter login and put donor PIN (4321), CODE accepted. Then go to adaptation and enter channel 50. Then enter ORIGINAL PIN with a 0 before (01234) press test and save. Pin and vin changed. Then adapt keys as usual with original PIN. Job done!!!
With RB8 clusters are bit different. I use original ODIS to adapt it and finish with vvdi2 to adapt all keys.
pin it this dash in eeprom? how you get pin from.donor?
@U.S "prepare dealer key by ECU data" can do like 2015 skoda octavia,2015 audi Q3,14、15、16Tiguan and part of 24C64、24C32 all key lost by OBD
@Hipolitogt all key lost or? consider all of the situations."File make key", cas and ecu(just which need the ISN) enough.
@lidons I think hiplitogt can test by other tool too,if it's also 7953,so~ haha
I mean like in mb vvdi that you can make keys without car, if I read key data I can see what keys are used. But if I want to make key with this data tells me to connect to car. It would be great to make it without car, it only has to write key data on key so it should work without car... I don't know if I explain it well... Will try to make a video/photos to show what I mean.
