EMCE159 (22nd May, 2018)
Even in new update? Car is 2013.
Not tried with new update
VVDI shows the same 8799 pin and 3 keys.... But when program chip then it writes the file but car doesn't. Also when open new file in VVDI2 then says UNKNOWN VERSION.
Could you perhaps write a chip with TANGO and send me the Key data and eeprom file and also make it with VVDI2 and send me eeprom so we can check where is VVDI making a mix up.
Hallo
Warum funktioniert VVDI2 nicht mit den letzten 2 Menüs?
Oder es wird nicht unterstützt.
Weiß jemand genau?
Hello dear Members.
Have VW beetle 2014 KeyLessGo key 5k0 ... ... AJ. Magneti marelli dash NEC v850 & 95320. VVDI2 read EEPROM by OBD and say error. and this true read by OBD is wrong. AVDI original say too can work with this dash only by damp. remove dash, read NEC and 95320, can add only immo data key by AVDI, key can start car near emergency coil. VVDI cant due any. but to work keyless key need rewrite all key by obd. this step i cant finish by all my devices(((
Maby any members have any idea???
all screen and all datas in add files. files name is next example """ VW Bittle '14 D70F3427GD(A) _ (vvdiProg)""" ... first NAME of car _ "VW Bittle '14" _ second what memory is read _ "D70F3427GD(A) _ third what devices use to due this _ "(vvdiProg) _
EMCE159 (23rd May, 2018)
I didn't have a guts to try it this way, without having any backup data.
Hi...
So in almost every update of VVDI2 they list J2534 Passthrough "BUG FIX" and Updates..... But does it ever work?
Did anybody get this thing to wok with VW, Toyota, GM or any other dealer software?
I tried with TECHSTREAM and nothing... Cannot connect to VIM.
I tried Honda pass trough and it worked.
Sent from my ONEPLUS A3003 using Tapatalk
PierreTheron (26th May, 2018)
