Page 101 of 144 FirstFirst ... 519196979899100101102103104105106111 ... LastLast
Results 1,501 to 1,515 of 2152
  1. #1501
    Feb 2013
    Default Opel Astra G 1.4 16v 1998 Delco Multec
    Could anyone please remove from this file P1405 and P0400 dtc please?
    Thank you and best regards
  2. #1502
    Nov 2017
    Ford C-MAX 2007 2.0 SID202 DTC OFF
    Вперше я працюю з SID202, мені потрібна допомога у видаленні DTC
    P2584
    P2585
    P2456
    P2452
  3. #1503
    Nov 2017
    For the first time I work with SID202, I need help in removing DTC
    P2584
    P2585
    P2456
    P2452
  4. #1504
    johak's Avatar
    Apr 2010
    Quote Originally Posted by mastakmetz View Post
    P2584
    P2585
    P2456
    P2452
    here you go
  5. The Following User Says Thank You to johak For This Useful Post:
    mastakmetz (8th November, 2017)
  6. #1505
    Dec 2010
    Poland
    citroen c3 sid804 please delete dtc p1350 p1351 p1352. plese checkcum calculated
  7. #1506
    Nov 2017
    [QUOTE = johak; 3139556] тут ти йдеш [/ QUOTE]
    ​Thank you so much, yohak. I'll let you know. You also have a message in your personal box for you.
  8. #1507
    Jan 2017
    Earth
    Default hello
    can you please
    dtc off p0230, p0180
    egr off (egr is blanked)
    Alfa Romeo 159 1.9JTDM 150hp
  9. #1508
    Nov 2017
    please dtc off p0406 egr is blanked,
    if you also want to put off other dtcs related to egr
    Ford Focus 2.0tdci 136cv sid 803a
    https://mega.nz/#!5rJxxZ4I!-_H6QcifC...HPtdmkkYq7tV_I
  10. #1509
    Oct 2013
    fiat doblo marelli dtc off please p0236
  11. #1510
    johak's Avatar
    Apr 2010
    Quote Originally Posted by multi666 View Post
    here you go
  12. #1511
    Nov 2017
  13. #1512
    Aug 2013
    prova quell'amico no ck
  14. The Following User Says Thank You to sisco1 For This Useful Post:
    iociprovo2017 (17th November, 2017)
  15. #1513
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    Quote Originally Posted by sisco1 View Post
    First - use english
    Second - What ecu is it?
    Wysłane z iPhone za pomocą Tapatalk
    Chiptuning - Diesel / Petrol / Stage1,2,3 / HIGH Petrol Tuning
    DSG TUNING
    DPF / EGR / TVA / SAI / Lambda
    Crackle map ( Launch Control + No lift Shift + Antilag )
    File Service
    PCMFLASH / BFLASH / AMT BST / AMT MPPS / TGFLASH / BITBOX / EDCSUITEPRO - Genuine USER
  16. #1514
    Nov 2017
    ok i try this thanks
    UPDATE: Work! Thanks
  17. #1515
    Jun 2013
    hi, could you delete p0220, p1409 and p2265 from this map?Thanks
