if there is no wire on pin 58 it is canbus systeem, for immo off you need emulator,,,if keys are good, you can set ecu in to virgin stateI have found an dump with your ori partnumbers on other forum and maded it immo off,,,but this is not tested solutionyou can try it if you want
try this dump first with Write protect 29f200 if you get any problem, then remove write protect
