Page 7 of 18 FirstFirst ... 2345678910111217 ... LastLast
Results 91 to 105 of 260
  1. #91
    Apr 2010
    If the car on the CAN bus does not have 58 pins, even though I have a resistor,
    Can I make a virgin dump and pairing again UCH,
    The failure was to not burn cold did not enter the code.
    greeting
  2. #92
    dadal's Avatar
    Aug 2015
    if there is no wire on pin 58 it is canbus systeem, for immo off you need emulator,,,if keys are good, you can set ecu in to virgin stateI have found an dump with your ori partnumbers on other forum and maded it immo off,,,but this is not tested solutionyou can try it if you want
    try this dump first with Write protect 29f200 if you get any problem, then remove write protect
  3. The Following User Says Thank You to dadal For This Useful Post:
    jfiljak (13th July, 2017)
  4. #93
    Apr 2010
    This is ok virgin dump and the car is running immediately, but it will not work without a key,
    the ECU wonix write protection 330 ohm resistor is not good.
  5. #94
    dadal's Avatar
    Aug 2015
    my both files are not from ecu vonix ( IUD ).. if your keys are good then problem is solved,,, do you have now information about RPM,TEMP, SPEED on dash ?
  6. #95
    Apr 2010
    Yes I have information about RPM, TEMP, SPEED on dash dump is ok ok . mhhauto
    Ecu vonix I made the instructions ,Write proteckt is not good..
  7. #96
    Oct 2015
    Ukraine
    Hi bro ! Need immo off renault scenic. Sirius 32n 8200057536 8200029658. 58 wire cut before start, but dont work
  8. #97
    Mar 2017
    Bogot? D.C., Colombia
    Quote Originally Posted by Zgama View Post
    Hi friend
    I send you the IMMO file OFF. You can cut the pin 58 or desolder the resistance that is connected to this pin. Please test and confirm operation. Thank you
    RenaultScenicImmoOff.rar
  9. #98
    Oct 2015
    Ukraine
    Bro, you dump the same as my clear .
  10. #99
    Oct 2015
    Ukraine
    Today again did reprog ecu and the car started. Thans !!!!
  11. #100
    Oct 2016
    Default sirius 32n
    pls help with this file
  12. #101
    antwnhszr's Avatar
    Dec 2009
    macedonia is greek....
    Quote Originally Posted by kina View Post
    are you raedy my dear.......
  13. The Following User Says Thank You to antwnhszr For This Useful Post:
    kina (11th September, 2017)
  14. #102
    Oct 2016
    Thanks Man all is okkkkkkkkk
  15. #103
    Oct 2015
    hi antwnhszr can make immo of for my sirius 32n ecu
  16. #104
    lion0304's Avatar
    Oct 2014
    Default Siriues 32 OFF
    Quote Originally Posted by Tedum View Post
    Here your file OFF.
    See instruction and start engine. Pass PM
  17. The Following 2 Users Say Thank You to lion0304 For This Useful Post:
    laraiedh (23rd March, 2021), Tedum (23rd September, 2017)
  18. #105
    gelencserg's Avatar
    Dec 2009
    Garage
    Hi Bro!
    Please help immo off.
    8200059086
    S110138000
    thalia 1.4 16v no ac
    pin 58 cut.
