Page 85 of 245 FirstFirst ... 3575808182838485868788899095135185 ... LastLast
Results 1,261 to 1,275 of 3668
  1. #1261
    tsistvan's Avatar
    Dec 2009
    HUNGARY
    thank you VAGVA youre help !!!!
  2. #1262
    May 2013
    hi code did not work
  3. #1263
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by tsistvan View Post
    waited your Rep dear
  4. #1264
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by MICKEYMAC1 View Post
    will you try one of these Long coding :
    10F162A220270AFD010F06E4011A2508460450806080A4F200 59000805
    12F16AA234272AFD010F07E4411A2948562C5480E08294F402 41003885
    waiting your feed back
  5. #1265
    May 2013
    sorry not work do you need more details of car
    thanks for help
  6. #1266
    Jul 2016
    Vilnius
    MICKEYMAC1, when you decide you really need a working coding, feel free to get in touch.
    I can calculate ABS module codings for:
    * Continental/Teves MK60EC1 and MK60;
    * TRW systems in Passat B6 / B7 / CC /Tiguan;
    * MK100
    * Bosch ABS8.2, ABS9.0 and ESP8.2, ESP9.0;
    * EBC 460 (UP!, Mii, Rapid, CitiGo, Fabia, Toledo, etc) New!
    ... and other VW/Audi/Seat/Skoda modules.I can assist with repairing \/CDS interfaces.
  7. #1267
    Feb 2012
    hi can you help long code audi a3 please
    WAUZZZ8P3CA111754
    ESP MK60EC1 0121
    1KO 907 379 BJ
  8. #1268
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by inaro View Post
    WAUZZZ8P3CA111754
    ESP MK60EC1 0121
    1KO 907 379 BJ
    here is your long coding :
    11424012092300FB881202E9901D004139080053401
    if my post was Useful , Press Thanks & Rep Buttons
  9. The Following User Says Thank You to vagva For This Useful Post:
    r-parts (22nd August, 2018)
  10. #1269
    Aug 2018
    Quote Originally Posted by vagva View Post
    one of these are your long coding :
    563B6008092300026A0F06E5901A0092350000
    543B8008092380022A0F01E5901A01423D0000
    Try & report and click "THANKS" and "REPUTATION" buttons
    Hello Vagva,
    I have ah new ABS BLock with 20 Byte, your long code ist 19 Byte long.
    Do you have more for me or maybe more info?
  11. #1270
    rvtecs's Avatar
    Nov 2015
    Default need coding long
    need coding long vw beetle
    please, use magic buttons reputation+thanks.
    Best regards. rvtecs
  12. #1271
    Sep 2012
    Ukraine ,Donetsk
    HI ! HELP ME PLEAS CODING ABS?
    1k0907379bs Jetta 2015year with keyless, start/stop ,3VWD17AJ9FM283547, LHD, engine CPRA, 1.8 TSI
  13. #1272
    Apr 2010
    EU
    Audi A3 2008
    VIN: WAUZZZ8P09B012019
    MK60EC1
    SW 1K0 907 379 CD
    HW: 1K0 907 379 AD
    Thank you
  14. #1273
    Nov 2009
    Hello can you help with coding?
    Golf 6 gti usa car mk60ec1 1K0907379AJ
    WVWHV7AJ2AW236958
    ENGINE TSI 2.0 CCT
    LHD
  15. #1274
    Mar 2017
    pmb
    please help mk6 gti abs long coding
    vin: wvwzzz1kzbw313247
    abs part number: 1k0907379BE
    MK60EC1
    engine 2.0 tsi ccz
    RHD
    immo off
    damos
    map packs
    tuning files
    egr dpf off
  16. #1275
    Aug 2018
    Hello, i bought a newer ABS and tried to calculate the coding myself. I get a „Coding accepted“ but when I go back to the VCDS main menu and back into the ABS menu, it‘s all zeroes again. I did not turn off the ignition while doing that. Does anyone have an idea what is causing this? Wrongly calculated coding maybe?
    Please note that the ABS is not yet installed in my car, i just connected the plug to be able to access it via VCDS. I‘d love to first code it, and then get my car to a workshop and have them swap it. Because I doubt they could code it themselves.
    Car: VW Golf 6 Variant 2010
    Engine: CAXA (1.4 TSI 122hp Gasoline)
    Transmission: Manual 6-Gear
    Old ABS: 1K0 907 379 AH (H30 0107)
    Old ABS coding: 143B400D092B0001280F02ED901E0040340000
    New ABS: 1K0 907 379 CC (H46 S0175)
    VIN: WVWZZZ1KZAM697495
    Left hand drive
    Front wheel drive
    No start/stop or similar
    TPMS: Yes, indirect.
    ESP Off button: Yes
    PDC: Yes, front and rear.
    Trailer hitch: Yes, retrofitted but by VW (OEM)
    Hill hold: Yes, please
    XPS: Yes, if possible
    Already retrofitted: Lane Assist, Side Assist
    Future retrofits: I plan to install the following soon: ACC, PLA2.0, TPMS with wheel pressure sensors
    Can anyone check on that? That‘d be great!!
