Results 1 to 15 of 80
Threaded View
    eprst's Avatar
    Jul 2011
    Russia
    Default Using JTAG to read/write the flash MMI3G
    I use TopJTAG flash Programmer to read/write the flash.
    The flash array data bus organization is 32bit (1 chip X 32), and the flash is cfi compliant.
    I assume the flash are connected parrallel, flashchip 1 holds D0 until D15 and flashchip 2 holds D16 until D31.
    The signal pins are connected according to the scheme below:
    Flash Pin JTAG device PIN Active
    CE W11/ cs0_n Low
    OE U11/ rd_n Low
    flash 1 - WE W12/ we0_n Low
    flaSH 2 - WE Y17
    / we0_n Low
    A0 Y9 / a2
    A1 W9 / a3
    etc continue until A23 (notice the offset of 2 adress lines A0 and A1 are not used)
    A23 AA1 / a25
    The datalines are connected 1 on 1, so
    D0 AB10/d0
    continue
    D31 AA20/d31
    First flash #WE -W12 - i can read/write, CFI is OK
    second flash #WE - Y17 - I can write, but I can erase it only fully, can not erase it partly,
    because the programm writes - common flash interface (CFI) Compliant - NO
    Screenshots are attached - "CFI-OK" is the first flash
    "CFI-error" is the second flash
    How To Solve That Problem?
    P.S. processor is SH7785, two flashes are Spansion GL512L
    Best Regards
  2. The Following 2 Users Say Thank You to eprst For This Useful Post:
    Faraday (23rd January, 2020), turgutsan (14th February, 2020)
