automotrizVIP (27th May, 2017), doctore (26th May, 2017)
You cannot do x6 2016 with r270, because the new type eeprom in dash cannot be erased..
I made x6 2015 with dash eeprom dq160 erase with r270 and fem modul block by can blocker install in cluster. I don t know what eeprom is in your cluster maybe new tipe you must open and look what you have good luck
From 2016 bmw use new 35160 will bring tamper dot on unless you use a 35160 emulator
automotrizVIP (29th May, 2017)
The eeprom in dash is a 35160 which needs an emulator to stop tamper dot coming on you will also need to do bdc by installing can filter in cluster or bdc module
I see, you have to emulat the board so you do not have communication with the FEM module
THE SUGGESTION IS GOOD, BUT IT IS LACK OF THIS COMPONENT.
I HAVE TO DO IT CORRECTLY.
I have also seen that if this FEM modulo, it is wrong the car is dead.
WINNER THE LOSER
Ok you must be right but it is definitely bdc module and the emulator is just for the eeprom not bdc you need a blocker for bdc dont ask for advice if you know better
I thought that this car could be made of the shape of a bench.but it is not possible
Some have been able to do with "original arbiters, others", by taking obd2?
Without this car getting damaged?
WINNER THE LOSER
