Mak88 (24th April, 2018)
For XC 60 2010+ you have few version where is the location of mileage . You have two version which you can change km 1. Reprogram CEM+ dash 2.Disable sinchro CEM-dash when you make new km on dashboard don't forget to check DDM/PDM if these module have stored old km you must do manually (on OBD read fleash+eeprom than with Jtag BDM erase full NEC in DDM/PDM and write flash which you prevous reading on OBD with UHDS) if you dont want to old km jump back :-) and at the and check ECU if you vant to make clear job .
Mak88 (22nd April, 2018)
Hello can you help me how to make volvo disley language change volvo V50 there is read flash i read the flash and now how to make it thanks alot
Sent from my Lenovo K53a48 using Tapatalk
now write file with other language, or change it manually in file
Mak88 (27th April, 2018)
U dont know how to change file my friend
hi
i've got a 2016 vw scirocco to do with dsg, is this safe to do with smok.
dj
shure i know how to edit volvo language. open file im hrx editor and have fun. is not easy but can be done
cannot make 2016 dsg
djollie (6th May, 2018)
Do you know qhat is the wey for Citroen jumpy 2007-2012 how to make it and how to clear this history and edc16 how to make it good job with smok thanks advance
Lancia Delta dash 2009 = ok in 5 seconds
Aynone have problems with the interface last months? I have a old version interface i have many read flash errors while reading a dash. also flashing the update sometimes goes wrong. I changed the multiplexer inside for a new type, same problem. I have one of the first designs so i wonder if someone have the same problems. I bought already a new laptop also. Smok thought it was my laptop. thanks.
