Results 1 to 5 of 5
Thread: Ducato 2.3 MJ
    Top Poster vankoal's Avatar
    Jan 2010
    Bulgaria
    Default Ducato 2.3 MJ
    Can someone Erase the DTC code P0601 ENGINE CONTROL MODULE CHECKSUM ERROR from Fiat Ducato EDC16C39.
    number7hd's Avatar
    Dec 2013
    EEPROM is faulty. Desolder EEPROM - read it, write to another one and put it back. If problem still is on - DUMP in EEPROM is faulty.
    If my solution helped You - do not forget to THANKS !!!
  3. The Following User Says Thank You to number7hd For This Useful Post:
    vankoal (30th November, 2016)
    dominik.m's Avatar
    Jun 2009
    POLAND
    number7hd is right.
  5. The Following User Says Thank You to dominik.m For This Useful Post:
  6. #4
    Jan 2010
    Bulgaria
    Thanks i will try .
  7. #5
    Senior Member maybach_'s Avatar
    May 2010
    EU
    Have problem with ducato fault P0601
    Someone can help check and repair the dump for me
    Thanks in advance!
    Be allways Thankfull!
