Results 1 to 13 of 13
    Feb 2010
    Romania
    Default Toyota prius Airbag Renesas R5F61721 mcu how to read?
    Hello.I have a Toyota prius Denso SRS unit 89170-47101 unit.
    What kind of tool can read this unit?Has a renesas RF61721 mcu.I have J-link but did not fint on list this kind of mcu.I have xprog box 5.50.Othe tool can't have this kind of mcu-s.so please, if somebody have some advise how to read, and how to connect programmer help me.
    Here i have some photos.Thanks
    lwood's Avatar
    Mar 2010
    city of angels
    if you do a quick search you will find many people have ask the same question.. the search feature is your friend..
    DON'T JUST SAY PRESS IT.....
    May 2014
    Send the unit to me, mate, and i will do it for you.
    Airbag crash/clear file Service.
    Feb 2010
    Romania
    Can i use CG100 III 3.92 programmer?Have tryed somebody this tool with this ecu?
    May 2014
    CG100 will not work for this unit.
    repairmymodule's Avatar
    Aug 2014
    USA, Earth, Milky Way Galaxy, Universe, Unknown
    Carprotool programmer with Renesas 172x activation.
    http://diagcar.eu/en/carprotool-acti...arprotool.html
  7. The Following User Says Thank You to repairmymodule For This Useful Post:
    illestibor (14th February, 2017)
  8. #7
    Jun 2010
    Canada
    do you have to remove the resistor
    If i helped you please press thanx
  9. #8
    Aug 2014
    yes but its just a 0 ohm resistor, so you can just short with solder when done programming
  10. The Following User Says Thank You to repairmymodule For This Useful Post:
    janushaan (16th February, 2017)
  11. #9
    Mar 2017
    do not believe it and do not remove it does not matter
  12. #10
    Brayn's Avatar
    Oct 2015
    Colombo
    better think is do it via CAN line. 100% working. everyday i do. no need clear file or encrypted files.....
    just need 16 minuets only.. need to remove resistor and connect reset pin to 5v tat's only need................
  13. The Following User Says Thank You to Brayn For This Useful Post:
    dragon100 (28th March, 2017)
  14. #11
    Dec 2009
    What tool does it via kline thanks
  15. #12
    Brayn's Avatar
    Oct 2015
    Colombo
    Quote Originally Posted by diagtech View Post
    Toyota Renesas can not do via K-Line
    Sent from my F3216 using Tapatalk
  16. #13
    Jun 2013
    Easy to do with Iprog+ with Denzo renesas script
