Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
  1. #16
    honingkoning's Avatar
    Jun 2010
    Dessert
    Quote Originally Posted by Shmortz View Post
    What mod I need to do? This is my second R270, old one is burned, but it was working like the new one...
    Change resistor on eep pcb, check on forum and you Will find the mod.
    Easy job.
  2. #17
    Jan 2017
    Already saw the rework but I'm to dump to find the right resistors in a EU shop.
  3. #18
    Shmortz's Avatar
    Apr 2010
    in the middle of nowhere
    Quote Originally Posted by honingkoning View Post
    Easy job.
    if you talking about this mod, I have two pcbs, the resistor is 1K, should I try to put in one of them 820R or no big matter?
  4. #19
    Jun 2010
    Dessert
    [QUOTE=Shmortz;2994315]if you talking about this mod, I have two pcbs, the resistor is 1K, should I try to put in one of them 820R or no big matter?
    [ATTACH=CONFIG]439440[/i
    I put 103 like in picture, But my tool always worked with all 35080 var.
    Wbr
  5. #20
    Shmortz's Avatar
    Apr 2010
    If I understand right the picture 103 resistor must be changed with 820-1000R, mine both are with 1K, why you did the opposite?
  6. #21
    Jun 2010
    Dessert
    Let me check what resistor i put on my pcb.
    Long time ago, i Will report
  7. #22
    Jan 2017
    Report pls
  8. #23
    Jun 2010
    Dessert
    Quote Originally Posted by zix1 View Post
    Report pls
    Sorry just checked i have about 820 ohm.
    For me all Ok, only thing sometimes sw crashes Then restart procedure and finally end Up Ok.
    Wbr Adam
  9. The Following User Says Thank You to honingkoning For This Useful Post:
    zix1 (14th April, 2017)
  10. #24
    Shmortz's Avatar
    Apr 2010
    I was wrong in my previous post, problem with erasing is with 35080V6/VP, 080DWQ is erased for seconds, after a few hours palyng I can erase V6/VP eeproms for some minutes, I did replace 74HC125 with 74HCT125M.
