Results 1 to 6 of 6
    Jan 2012
    Default Piaggio/Gilera MIU1 ECU Key Data (Temic11/T5)
    Hi all,
    I was hoping someone could pull the string data for both keys from this dump... I have no idea which encryption is used.
    I did find the transponder identifiers, but thats easy.
    Key 1: BE FA 00 00 01 75 0F 56
    Key 2: BE FA 00 00 01 73 96 04
    Thanks in advance.
    kiszka's Avatar
    Aug 2009
  3. The Following User Says Thank You to kiszka For This Useful Post:
    dcggames (5th April, 2017)
    Jan 2012
    Thanks for your reply!
    These are the identifiers indeed. But what about the transponder streams?
    Oct 2016
    Hello
    key 1 :
    7D 5F 00 00 80 AE F0 6A
    KEY 2 :
    7D 5F 00 00 80 CE 69 20
  6. The Following User Says Thank You to datagaraj For This Useful Post:
    dcggames (4th April, 2017)
  7. #5
    Jan 2012
    Thanks! That really helps me out!
  8. #6
    Jan 2012
    Just to be sure. Should these two transponders work?
