I remapped my 2001 A4 AWX 1.9TDI
I changed:
Limiters
SOI
injection duration and turbo maps
But still not getting any increase in power, can someone figure out whats wrong with it?
Original File and Tuned File:
Ori and Tuned file.zip
I changed:
Limiters
SOI
Hi. I have question also!
Does after these changes engine work normally yet?
Yes, but the engine makes full boost(1.6bar) and I think it doesn't reach my fuel goals, so it might be running way too lean.
Ok, but do you know how to adjust duration maps to make more power, I guess I need way more ?? 5? or maybe 6? more?
But do I change this in every duration map, they are not very similar?
this tune is totally wrong
bFlash/Kess/Ktag/CMD Master
DPF/EGR/DTC/AdBlue/ChipTuning. ------>PM
have smoke on it?
You must make increase from 1000rpm!! Edc15 will not give power when you make increase after 1000rpm. Maybe 5hp..
Wait tomorrow so i send you file and give you 100% guarantee for 30hp.
Regards from Belgium
This is working 100% file.
I make always these tuning, 101hp with this tuning 139hp on dyno (ATD engine)
I checked you tuned file, you must feel the difference...
Try this file, when not changes anything make log of your MAF and upload screenshot here.
Any DTC in the car ?
Hit thank if i helped.
Pass on P.M.
AUDI_AWX_MOD.rar
Use my file and enjoy the PowerPlus Feeling
tuned stage2 , hotstart fixed
i looked at your file.Why you not changing driver wish map?
which file you looked ? and from who you get pass ?
if you look on my PowerPlus file , you see all maps is ok and you ask me for DW map , really ? on 100% throttle stock software request 70mg. On TQ map i have 6056 , so why need to touch DW map h?!!!!!!!!!
And Yes i change DW map on 56 , 80%
if you have no clue, please psssssssssst all maps with limiters touched, maf map limters set to 65mg, User
Cotulla knows how good is the file ! good power with no vibrations from low rpm!!!
AWX have 5 gear, 228mm not strong clutch!
Last edited by PowerPlus; 3rd May, 2017 at 03:36 AM. Reason: special infos for user Ignasvw
