Results 1 to 7 of 7
    Apr 2017
    Default 05 Corolla with MMT, several trans fault codes
    Hello
    My MMT 2005 corolla has been given me problems. It is jumping into neutral while driving. I scanned the car and found the following trouble codes. PO808, PO810, PO812, PO900.
    Anyone ever had these?
    Was looking at a TSB for PO810 and my sedan was manufactured in UK and states ECU needs to be replaced with new design. I had this recall done years ago. So assuming something else is trigerring the faults. Clutch bad? Clutch position sensor?
    Jun 2013
    Poland
    Change the clutch
    bursuc's Avatar
    Oct 2011
    inside MCU
    Check clutch actuator first and reprogram gearbox with it or similar.
    Sent from my SM-G928F using Tapatalk
    Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
    Apr 2017
    Quote Originally Posted by wbart View Post
    Change the clutch
    You think cluth is bad? Experience with this or just assuming like I also think may be clutch?
    Quote Originally Posted by bursuc View Post
    I removed clutch actuator, had no play in it and seems fine, unless sensor or motor itself are shot. One of the codes is for the sensor, but asks you to look at other things first such as fuse and relay. Havent found any info on the relay.
    Thanks to both.
    Jun 2013
    Poland
    Attachment 441315
    Look this
    Apr 2017
    Greece
    Did you solve it?
    Apr 2017
    Quote Originally Posted by Stelaras View Post
    Did you solve it?
    No I did not.
