part number please just to confirm i see if i have tested solution
ssmax (2nd December, 2017)
VOLVO XC60 2014 P31406637 0285012268 << i have a tested solution for this
Yes, it is, same as mine
I appreciate when you give me "Thanks and Reputation"
here you go, manual cleared from a tested solution
all the best
regards
slick_dick
thanks friend, i will wirte now
Hi all
i have here a Volvo XC60 2015 with P31406637 Partnumber 0 285 012 268
and want to clear the crash in this module can you help me with this one
From the netherlands
your file cleared
join date 2009 .. time you started helping out a bit more mate
pass in pm
good luck
slick
“There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
mapino (21st October, 2018)
Thanks Slick for your efford
i tested the file in the XC60 airbag module but it did not clear
what i noticed is that after words when i Read the file back it changed again
see attachment i also took a snap of the fault codes
i noticed the same with ypour original read!!
your original crash file looked wrong to begin with
my attempt at clearing the above was trying to repair the data and remove crash
thanks for that
do you still have the file that you loaded in to your XC60 mabe i can load that and see what happeands
what can i do further
can you post diagnostics codes and fault description??
did you remove eeprom from board before reading??
did you remove eeprom from board before reading?? = Yes But the previous owner let sombody that i do not know work on the module
Thanks again
try this
Also be aware there is another variant in V60 that is same as XC60
good luck
slick
Slick
thanks for helping but it did not help i am stuck now
