Results 1 to 7 of 7
    rafal's Avatar
    Jul 2010
    UK - PL
    Default vw caddy 2006 airbag modul 6Q0909605AH
    hi all. can somebody upload clear file for 6Q090605Ah vw52 please ?
    1L02m
    Apr 2017
    EU
    Hello ,
    here your file.
    What about coding
    Do Not Forget Press Thank
    No Report , No Thank = No Help
    rafal's Avatar
    Jul 2010
    UK - PL
    i will try to do by vcds
    Apr 2017
    EU
    What happened to your file
    rafal's Avatar
    Jul 2010
    UK - PL
    i tried to read this motorola and i deleted by mistake
    Apr 2017
    EU
    Ori coding of course you do not know,Vcds will not change the coding,Only files with different codings remain.
    Check what coding is in the file that I sent you
  7. The Following User Says Thank You to foks025 For This Useful Post:
    rafal (27th May, 2017)
  8. #7
    rafal's Avatar
    Jul 2010
    UK - PL
    problem solved
