Results 1 to 2 of 2
    Apr 2010
    Default H2s multi room IPTV
    hi guys
    Right had IPTV on my main box getting a 30mb speed connection from lan plug all running sweet, decided to get multi room on another box H2S in room direct plugged into the router 70Mb + donwnload connection ( Measured through plug in)
    One is Open ATV the other wooshbuild, now i am getting channel freezing mainly when i change channel on one box it freezes the other????
    Weird was all fine before adding second box almost like there is a conflict somewhere. IP adrresses on boxes are different.
    Cheers
    P&D's Avatar
    May 2010
    If it works the same as all the rest do
    one IPTV you know what to one box .......2 to two boxes.....one won't run on 2 at the same time unless the boxes both have the same IP address
    could be the problem
