Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
  1. #16
    May 2017
    Quote Originally Posted by janushaan View Post
    i dont think these can be done by obd,,, let him try ,, charge him bit extra i do these around $80,, you can always reseal with bit of silicon
    The carprog support send me this
    http://codecard.eu/carprog/software/...prod_2518.html
  2. #17
    Jun 2010
    Canada
    read it carefully ,, not for eeprom your module has 95160 eeprom,, so that is not going to work,,
    CarProg software for Opel, Chevrolet, GM 2009-2015 airbag sensor by OBDII: read/erase fault codes, erase "crash data" or "computer malfunction - internal error" fault.
    Not possible to read/write EEPROM for now. <<<<-------
    Works with Infineon, MAC, 9S12 processor based airbag sensors:
    If i helped you please press thanx
  3. The Following User Says Thank You to janushaan For This Useful Post:
    rmelo84 (22nd June, 2017)
  4. #18
    May 2017
    So I spent $1500 usd just to read eeproms?
  5. #19
    Jun 2010
    Canada
    sounds bad if you put it that way,, if you gather enough business you will make your money in no time,, ,, but they give solutions as well not just eeproms,, crash calculator is included,, so far carprog is best and worth buying if you want to get into this business,,
  6. #20
    May 2017
    Besides that, I need something to clear crash by OBDII, if I can't, then work with the module.
  7. #21
    May 2015
    cut it where black lines i drew,, takes min ---
    Attachment 458398
    cut ? Why need cut if you can connect without cutting ?
    IF I HELP Don`t forget to use Thanks button and reputation
  8. #22
    May 2017
    Quote Originally Posted by Seselis5 View Post
    How?
  9. #23
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Quote Originally Posted by rmelo84 View Post
    How?
    You wish this one can be done OBD, but the fact is it cannot. janushaan was pretty much on point with the info.
    This was already a losing battle trying to do these for a mere $40
    🔥Wacka Wacka 🔥
  10. #24
    May 2017
    Quote Originally Posted by FxShaw View Post
    I know.
  11. #25
    Jun 2010
    Canada
    either you cut or scrape brown gunk,, i like to cut it use the eeprom clip on 95160 unless you have other way to connect please share,,
  12. #26
    May 2015
    here you go
  13. The Following User Says Thank You to Seselis5 For This Useful Post:
    rmelo84 (25th June, 2017)
  14. #27
    Dufner
    Johnner's Avatar
    Jun 2010
    Éire
    Repair and FX...keep it civil guys,please....no need for it...
  15. The Following 2 Users Say Thank You to Johnner For This Useful Post:
    FxShaw (26th June, 2017), janushaan (26th June, 2017)
  16. #28
    Jun 2010
    Canada
    no idea what started it,,,
  17. The Following User Says Thank You to janushaan For This Useful Post:
    repairmymodule (26th June, 2017)
