Results 1 to 4 of 4
    super jumbe's Avatar
    Dec 2008
    Livingstone
    Default 2003 Citroen C3 1.6 16v HDi diesel showing ECO MODE none starter
    BATTERY 12V and engine is cranking fast.
    Lads got the above car towed in the garage this morning getting those fault codes none starter, I can not find where the shut off switch located. any idea.
    FAULT COMMING UP
    1. Engine shutoff sol
    2, TP SENSOR/SWITCH
    Any help very much appreciated, thanks in advance.
  2. The Following User Says Thank You to super jumbe For This Useful Post:
    trinicolin (23rd June, 2017)
  3. #2
    Dec 2008
    Livingstone
    14 years old car and no 1 came across this issue!!!
    Nov 2015
    Lancashire
    This one is an easy one look for the fuel cut off switch on pump usually when the switch gets old it sticks when engine is hot and will not allow car to start you need to replace with the new switch, you could give a whack and see if the car starts.
  5. The Following User Says Thank You to WD40 For This Useful Post:
    super jumbe (24th June, 2017)
  6. #4
    Dec 2008
    Livingstone
    Sorted it, replaced fuel cut off swithed started first time thanks.
