Page 1 of 35 12345611 ... LastLast
Results 1 to 15 of 523
    Aug 2016
    Default 2017 New CGDI Prog BMW
    someone know abouth this tool? i see in description work cas4.cas4+ all key lost
    lik
    P.S.
    if i crash rules with link,please admin edit post,i can't upload picture.
    rob h's Avatar
    May 2011
    Probably a multitool clone, cas4 and cas4+ by dump.
    The price is good, if it works.
  3. The Following 2 Users Say Thank You to rob h For This Useful Post:
    doctore (17th August, 2017), lidons (29th July, 2017)
    Jan 2017
    USA ����
    Note: this device need avtivate every 3 months, and our price included 6 months free activation(2 times), after 6 months, it will cost 30USD each 3 months.
    1.BMW CAS1/CAS2/CAS3/CAS3+/key increasing matching,KEY all lost matching,CAS computer replace,CAS3+/P4X above version can directly downgrade by OBD in 5 minus 100% safety.
    2.BMW CAS4/CAS4+/Support key matching,support key all lost matching.
    3.Support BMW key inspection,can check key what status in.
    4.Support BMW engine computer DME replacement.
    5.Support BMW MSV80/MSD80/MSD85/series OBD read ISN code (no need to split computer when matching key)
    Exciusively support in Domestic
    6.Support BMW Key unlock.CGDI MSV80 BMW Car Key Programmer CGDI Functions:
    1.Update in real time,products updated in zero cycle time,support model added in real time.
    2.BMW CAS3/CAS3+Data repair--support change replace and split CAS computer,BMW MSV80/MSV80.0/MSD80/MSD80.0/MSD85/engine change computer,ISN code reading and writing.
    3.Equipment security greatly enhanced, the hardware anti-crack,anti-software copy.
    Model Has key to match key Without key to match Read ISN code Replace engine computer DME BMW Key unkock Working time
    CAS1 support support support 1 minute
    CAS2 support support support support 1 minute
    CAS3 support support support support 1 minute
    CAS3+ support support support support 1 minute
    CAS4 support support support 30 seconds
    CAS+ support support support 30 seconds
  5. The Following User Says Thank You to sleepyrz For This Useful Post:
    folarinm (21st September, 2017)
  6. #4
    drugowaz's Avatar
    Mar 2015
    Lithuania
    it read isn for msv smd ecu by obd? i doubdt that
  7. #5
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Is there any news about this tool?
    what can and can not due
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  8. #6
    doctore's Avatar
    Nov 2015
    Colorado Denver
  9. The Following 2 Users Say Thank You to doctore For This Useful Post:
    p1et (30th August, 2017), yugo45 (13th September, 2017)
  10. #7
    From Cas4+ not possible retrieve ISN by nothing. So it must be good read ECU then.
  11. The Following User Says Thank You to qwojtus For This Useful Post:
    bearheroes (4th September, 2017)
  12. #8
    Jun 2016
  13. #9
    Dec 2015
    LITHUANIA
    Is there anyone using this device ?
  14. #10
    ThiagoArgentino's Avatar
    May 2016
    Brazil
    BMW Explorer clone Tool, what to expect from a cloned machine ...
    https://www.facebook.com/carcgprog/p...05198500296740
    Solutions in the area of automotive coded keys, all automakers.
  15. #11
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by ThiagoArgentino View Post
    What was the content? Page is dead now
  16. #12
    yugo45's Avatar
    Apr 2010
    It looks like this will be competition for other tools.
    I really want to see MSV80 in action.
  17. The Following User Says Thank You to yugo45 For This Useful Post:
    doctore (13th September, 2017)
  18. #13
    Nov 2012
    UE
    hi,
    someone tested BMW CGDI prog ?
    thx
  19. #14
    Saulius Saulius's Avatar
    Aug 2010
    Herts, UK
    Will test it soon, waiting by dhl.
    MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
    We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
  20. The Following 9 Users Say Thank You to Saulius Saulius For This Useful Post:
    delek (26th September, 2017), doctore (24th September, 2017), kronk92 (25th September, 2017), lion0304 (24th September, 2017), maxim1 (24th September, 2017), p1et (24th September, 2017), u.s (25th September, 2017), whiskeyman (24th September, 2017), yugo45 (24th September, 2017)
  21. #15
    Dec 2015
    LITHUANIA
    Waiting for review.
