Results 1 to 4 of 4
Thread: Garage leak
    DK Veteran johnboy1974's Avatar
    Dec 2008
    glasgow
    Default Garage leak
    Guys I've got some water creeping into my garage underneath the walls when it rains heavily.
    The garage is rendered breeze block built on a concrete slab. I'm thinking of running a line of waterproof mortar along the outside wall and then the inside wall. Would this be correct to remedy?
    Sent from my iPad using Tapatalk
    Meat-Head's Avatar
    You could get a massive pile of DK thanks buttons, line them along the seam
    as you say at the bottom, then cover in car undersell eal, iShit the paint on stuff that sets
    since when is there non water proof mortar
  3. The Following User Says Thank You to Meat-Head For This Useful Post:
    super jumbe (19th September, 2017)
    Mar 2010
    dont know what will work but know what doesn't work.....
    A nice little triangle of mortar pointed againt the joint where the wall meets the base. After a very short time you end up with lots of 3 - 4 inch triangle shaped bits of mortar.
    ifred's Avatar
    Jun 2010
    1 make sure the ground level around the concrete base is lower and not water logged if not a French drain (https://en.wikipedia.org/wiki/French_drain) all around will help the water seep away from the base.
    2 check guttering for leaks and blockage ie overflowing
    3 rake out bottom edge of mortar joint with base then reseal with mortar or a frame sealant.
    4 option if all above fail knock down garage and rebuild to do this you could drive too big vehicle into garage so it collapses then claim on insurance Meaty could assist on this last phase
  6. The Following 2 Users Say Thank You to ifred For This Useful Post:
    GastonJ (18th October, 2017), Meat-Head (23rd August, 2017)
