Results 1 to 14 of 14
    Jun 2010
    Default prod off mercedes w203 ALPINE
    this is the prod off of alpine mercedes radio test on bench ,and any mercedes car
    cheers
  2. The Following User Says Thank You to zabra For This Useful Post:
    shooting (18th August, 2017)
  3. #2
    shooting's Avatar
    Feb 2010
    WALES
    Quote Originally Posted by zabra View Post
    cheers
    Where is the Original "Prod on" dump for us to compare?
    wbr
    Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
  4. The Following User Says Thank You to shooting For This Useful Post:
    Decode Ghost (19th August, 2017)
  5. #3
    Jun 2010
    in this forum there is plenty of original dump for this alpine cm1010 or cm1120 it work on all alpine radio
    prod go for ever, the dump in this prod off have a lot off line changed its not one or tow bit solution
  6. #4
    shooting's Avatar
    Feb 2010
    WALES
    Which is why I asked for Original, to reverse engineer dump
    wbr
  7. #5
    Jun 2010
    you can try to compare but its very hard solution you can use it as it is
  8. #6
    shooting's Avatar
    Feb 2010
    WALES
    With Original it would be easier
    wbr
  9. The Following User Says Thank You to shooting For This Useful Post:
    irfa (18th August, 2017)
  10. #7
    Jun 2010
    original dump
  11. The Following 3 Users Say Thank You to zabra For This Useful Post:
    Decode Ghost (19th August, 2017), irfa (18th August, 2017), shooting (18th August, 2017)
  12. #8
    Raimax's Avatar
    Nov 2013
    LT
    original dump
    Completely different dumps. Worthless of your information
  13. The Following User Says Thank You to Raimax For This Useful Post:
  14. #9
    Jun 2010
    you are right the original file is from a cm1010 radio,the prod off is from other radio but same i receive it for repair
    and when i test it on bench it still on without prod ,test it on many radio and work 100 100 on bench and in car
    so i decide to share it with forum members
  15. #10
    shooting's Avatar
    Feb 2010
    WALES
    Original from your Prod off is the only Original we are looking for, all others are meaningless
    wbr
  16. #11
    Oct 2017
    hello everyone, help turn off the PROD ....cm1010 Alpine
    send me PROD OFF in personal
  17. #12
    Jun 2010
    to raimax and shooting ,i get the original dump today and here it is:
    trying to compare found difference in line 150 160 170
    cheers
  18. #13
    Raimax's Avatar
    Nov 2013
    LT
    cheers
    Thanks. I will try experimenting
    If you don't like it * close your eyes
    --- Geros dienos ! ---
  19. #14
    Jun 2022
    Turkey
    hi. Prod off pls.
