Page 34 of 172 FirstFirst ... 2429303132333435363738394484134 ... LastLast
Results 496 to 510 of 2578
  1. #496
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by ganimo View Post
    is the BCM (body control module) the same as gateway, or r they completely two different parts? thx in advance.Attachment 515466
    Buy this one and will be ok
    https://www.aliexpress.com/item/For-...ceBeautifyAB=0
  2. The Following User Says Thank You to lion0304 For This Useful Post:
    ganimo (21st March, 2018)
  3. #497
    Jan 2018
    usa
    you should start charging for your help......i will if i ever get as much knowledge as you in this field..
  4. #498
    lion0304's Avatar
    Oct 2014
    Compare to others here, i'm just starting in this field. And i earn my life with my every days job.
  5. The Following User Says Thank You to lion0304 For This Useful Post:
    newone (21st March, 2018)
  6. #499
    EARTH
    can make ESL W211 reset?
  7. #500
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by datapage View Post
    It still cannot do, FVDI with database can virgin.
  8. #501
    Sep 2013
    Quote Originally Posted by lion0304 View Post
    I heard that they will sell extra adapter for esl.
  9. #502
    bram380's Avatar
    Aug 2009
    Indonesia +628153111774
    not support for now,
    may be next update.
    Read esl by k-line and post here data (proper tool)
    I will calculate password for erase.
  10. The Following 3 Users Say Thank You to bram380 For This Useful Post:
    datapage (27th March, 2018), lion0304 (22nd March, 2018), yugo45 (24th March, 2018)
  11. #503
    EARTH
    [QUOTE = bram380; 3244681] [/ QUOTE]
    thank you bram380, you already helped me solve this in my other post. yesterday.
  12. The Following User Says Thank You to datapage For This Useful Post:
    bram380 (22nd March, 2018)
  13. #504
    p1et's Avatar
    Oct 2013
    When I want to use infra red key for getting psw from W203 2002 year with 1 existing key what to choose in program? Copy with or without key? I can't see explanation of using IR adapter in manual. Or just click copy with key (as working key available) and then software will tell me what to do, use IR or put key into EIS etc.? I have customer arriving with this car and I'd just like to know what to do from beggining. I only did newer models using existing key to get psw by putting it to EIS.
  14. The Following User Says Thank You to p1et For This Useful Post:
    fricker (2nd April, 2018)
  15. #505
    lion0304's Avatar
    Oct 2014
    W203 is Kline EZS, and when you use only IR simulate key to read PSW this meaning: AKL (COPY without key)
    And with AKL Kline, CGDI doesn't support.
  16. #506
    p1et's Avatar
    Oct 2013
    Hmm, okay. I thought it support as I saw VVDI MB working on old W203 HC08 EIS all in car with just IR adapter to get psw. I thought old K-Line EIS with HC08 (W203, W220) is 100% with IR adapter.
    EDIT:
    Customer arrived and first thing I tried was copy with key option. I was expecting some kind of failure that way but In like a 15 min process of putting (and rotating sometimes) key to EIS and CGDI device, finally I got psw. Well this was 2002 year so I think it must have been HC08 which I thought this way is impoissible but maybe I'm wrong or misleading facts... But the fact is I programmed new key in like 30 min all in car using existing key but the car was not happy of BE key and after like 10 starts it is not working anymore. It unlock ESL but cannot turn anymore. Remote working OK. On monday I will program ori NEC key, should be no problem.
  17. The Following User Says Thank You to p1et For This Useful Post:
  18. #507
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by p1et View Post
    EDIT:
    I've made a G class 2000 with W203 EZS to add key, it take more time but work to get PSW.
    Write 2 BE key, one start sometime and dead. Other not work at all.
    It the seconde time with old car that BE compatibility problem. Solved with ori Nec key.
  19. The Following 3 Users Say Thank You to lion0304 For This Useful Post:
    lalaina74 (25th March, 2018), p1et (25th March, 2018), yugo45 (26th March, 2018)
  20. #508
    Sep 2013
    W204 EIS fold down on the floor with key in. After this not possible to read password key and no more ignition. But fortunately I read it on the car. So was easy to make clone of eis. Now all ok.
  21. #509
    p1et's Avatar
    Oct 2013
    That recent W203 didn't even like Abrites TA21 PCB. Same situation like on China BE key as I described. Wrote original NEC with CGDI and everything work well.
  22. The Following 2 Users Say Thank You to p1et For This Useful Post:
    lion0304 (26th March, 2018), yugo45 (27th March, 2018)
  23. #510
    EARTH
    EIS W211_H912 slk200 2005 eis w211 mcu 1l59w XPROG KEIS CGDI MB=OK
    EIS W211_S912 E500 2005 eis W211 mcu 3K91D XPROG KEIS CGDI MB=OK
