You must to have tool that read, whrite immo data (pin, mac, cs, .......). If dash is micronas after 2006y. you must to read flash and eeprom, to make working key.
I have smok full, but ori dash was vdo and donor is visteon so can't write sec data only. Smok have visteon learn key no need of flash
Immob active will shows onlcd...
Use sec block helper and transfer data manually.
And why on the Earth someone will put Visteon dash if has Micronas. Visteon dash is nothing but junk.
amigokola (24th October, 2017)
Yugo45 in visteon can't see pin mac.... Crypted,and when change data in sec blok save button is grey, cant save changes
Can you post Sec block form micronas , and full read eeprom + sec block form Visteon.
Here is, I already tried to write data from ori to sec block od visteon but cant do that
Here is the test file.
bearheroes (29th October, 2017), ziko (29th October, 2017)
Other option
Immo off ECU, write mileage and key to cluster change coding, straight forward way if the immo is not an issue for you.
Or get correct cluster VDO which is pretty cheap used and is easy job with immo on.
Ok hope will solve like this yugo45 said. Vdo chip but this is5th dash to same costumer, all have bad LCD issue
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
