anyone ? have any idea ?
4d id62........
mehmet becker (25th November, 2017)
hi can you maby take a look on witch of these files is the right one ?
i tryresd with xprog tried 2 chip type as i can not read what chip it is but i got to different readings
thank s kind regards mehmet
Upload eeproms
mehmet becker (9th December, 2017)
hi sorry i tought i uploaded them
kind regards
anyone maby have a reset file for this ecu kawasaki z800 21175-0789 made in indoensia
or does anyone know how to keydata is written in the bin file ???
thanks and kind regards
check eeprom 93c86
hi
yes i checked i found ra86
if read as 93c86 depending on the chip i get different bin files see attachments
can you add for mee key data ?
mehmet
checked the file ?
yes it is work file
mehmet becker (12th December, 2017)
If you unzip there are 2 files i read
Witch one is ghe good one?
Can you als read out key data for me? Or add a key
Thanks regards
mehmet becker (13th December, 2017)
Thanks but does anyone know how the key datat is written cause i only see 8 number ahould there not be 11 numbers or somthing?
Thanks regards
