you have any logs from car? you get any dtc or limp?
ibiza flash read.bin.rarI have a stage 3 BJX engine (bigger turbo,camshafts and injectors). i have problem with boost pressure, i can't go higher than 0.8 bars. the tuner told me that he has setted up boost pressure to 1.2 bar but still can't go higher than 0.8 bar. can somebody check my file to confirm that my map is ok???? i need 1.2 bar boost pressure
Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
POPS & BANGS (Schubabschaltung, Crackles) on allmost every petrol
how to get logs? i have wow clone (wyrth) and i borrowed kess for a few days to read my map
vagcom or me7 logger, probably you have a problem on your turbo or your n75,
maajkii (22nd November, 2017)
N75, DV, boost leak, underpressure.... a lot of parts to check
Wysłane z iPhone za pomocą Tapatalk
Chiptuning - Diesel / Petrol / Stage1,2,3 / HIGH Petrol Tuning
DSG TUNING
DPF / EGR / TVA / SAI / Lambda
Crackle map ( Launch Control + No lift Shift + Antilag )
File Service
PCMFLASH / BFLASH / AMT BST / AMT MPPS / TGFLASH / BITBOX / EDCSUITEPRO - Genuine USER
i have cheked everything. i even swaped all sensor form a car that works fine ,i cheked wiring. i'm almost sure that the problem is in ecu, can somebody confirm that the setup of my map is 1.2 bar? with vcds i read 0% duty cycle at 0.8 bar
Hi, i mean file is good, i have same problem with car like you.... In my case is bad fabric blow off valve (spring have small pressure for valve, when you boosting, your boost leak back to filter...
My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
My help not for free, press THANKS and REP, for make me HAPPY
im not using passwords, my work is for this forum and members free
I think problem is in KFLDRL, please test this file
i disconected turbo pressure tube from N75 and i got 1.7 bar!!!! so my turbo works fine
BRASTY (22nd November, 2017)
to n75 come vacuum, no pressure. DONīT WOORY YOU LEARN IT
If you have tested n75 from ok car, maybe is vacuum leak on your car
thank you all for your advices. i will try andrei2015 map tomorrow
how bar is your MAP sensor are you modified the MAP or not ???
are u sure u have the correct connector from n75 on the n75 not the connector from n249
your dtc from n75 is off :-)
than why all rpm so high ??
bad idle or what ?
tell us what injectors ,hfm , inside ?
i think deka 630 and s3 hfm
what turbo is inside ?
test how many boost u now have i have also enable n75 dtc
Tuning Cars and Trucks, Immo off , DTC delete, DPF off
BRASTY (23rd November, 2017)
