Results 1 to 8 of 8
    Sep 2014
    Somewhere
    Default Dacia Duster 985106190R clear needed
    Hi to all!
    Please help with a clear file for this module:
    Continental
    A2C85841702
    985106190R
    13.11.07
    02 H02040 s1630 c151
    The module is from an Dacia Duster.
    Thanks!
    Nov 2017
    UK / PL / UKR
    error file size..
    what You used for read this dump?
    Sep 2014
    Somewhere
    jlink...
    Gues is the all memory
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Dataflash 64kB area ...
    You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
    If I helped, please, use magic buttons reputation+thanks.
    Best regards.
    Dragon
  5. The Following User Says Thank You to dragon100 For This Useful Post:
    Jashmine1983 (15th December, 2017)
  6. #5
    Sep 2014
    Somewhere
    Range from 0x800000 to 0x80FFFF.
    Here it is...ecu locked.
    Thanks!
  7. #6
    dragon100's Avatar
    Jan 2012
    First you must unlocked with diagnostic or just try your cleared file, clear errors, switch ignition off for 10 sec, switch ignition on, clear errors again and report, pass in pm.
    Best regards.
    Dragon
  8. The Following User Says Thank You to dragon100 For This Useful Post:
  9. #7
    Sep 2014
    Somewhere
    Quote Originally Posted by dragon100 View Post
    Thanks Dragon but I've tested with another file and worked....I've attached Chinese J-link connection and tested file.
  10. The Following 5 Users Say Thank You to Jashmine1983 For This Useful Post:
    dinar (26th April, 2019), Divgrp (30th December, 2020), dragon100 (16th December, 2017), jaiden (18th February, 2018), tecnocar (21st December, 2017)
  11. #8
    Dec 2020
    IMG_3781.jpgIMG_3775.jpgспасибо всё работает
