Results 1 to 7 of 7
    Jan 2018
    Default Which interface to read & write Suzuki GSX-S1000 motorcycle ecu?
    Dear Gentlemen,
    I'm looking for an interface to read & write Suzuki GSX-S1000 motorcycle ecu.
    The ecu is a Denso, only see following information on it: 32920-04K31 112600-2112 NEP244.
    Thank you in advance!
    Regards
    Tony
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    piasini...............
    Chiptuning - Diesel / Petrol / Stage1,2,3 / HIGH Petrol Tuning
    DSG TUNING
    DPF / EGR / TVA / SAI / Lambda
    Crackle map ( Launch Control + No lift Shift + Antilag )
    File Service
    PCMFLASH / BFLASH / AMT BST / AMT MPPS / TGFLASH / BITBOX / EDCSUITEPRO - Genuine USER
  3. The Following User Says Thank You to maajkii For This Useful Post:
    B28NER (14th January, 2018)
    Jan 2018
    Thank you! Also for model year 2016 EURO3?
    Jan 2018
    Piasini NOT WORKING
  6. #5
    Nov 2009
    Spain
    Hi M8,
    Ktag is your tool.
    Regards.
    Chiptuning file services ,custom remaps, inmo off, egr off, dpf off, adblue off, flaps off, tva off, lambda off, speed limit, selective dtc´s deleting ,etc.
    Worldwide assistance.
    All brands, All vehicles, All files.
  7. #6
    Feb 2018
    Have you checked if Piasini can do it? Probably have to cut out a small piece of it to get access to the aud port for reading with piasini.
    Also like jnoroeste mentioned maybe you can use ktag with 144300t107 cable
  8. #7
    Nov 2009
    koln, germany
    piasini is ok i read with it i can give you my file
