i m asking too for long time difference between y17dt and y17 dtl and y17dth
Lads I have in garage 2008 VAUXHALL CORSA D 1.3 CDTi with ECU water damaged, the number is Z13DTJ
(1) Corsa D ECU 1.3 CDTi Diesel 55198930 CN
Is it possible to programme another ECU with deferent number this one Z13DTH?
(2) ECU CORSA D 1.3 DIESEL 55566039 HK Z13DTH
Basically the damage ECU is Z13DTJ and the new one I have got is Z13DTH is it worth programming?
Thanks in advance.
Note:All information given is to be used for educational purposes only and should not be taken seriously.
super jumbe (15th January, 2018)
What ever has any one managed to programme successfully?
I heard if you change the full kit it should work can any one confirm that.
I have a car with this problem too. My ecu is 55563498. I cannot find an identical replacement anywhere. In someone has a list of compatible part numbers it would be appreciated.
I think its because the engines are slightly different, One has flaps, one has dpf, one has electronic egr. So it may start the engine, BUT you wil alwaysl have fault codes for the missing units.
Told if they are similar serial numbers they should work I will let you know the result once I get hold off them…
ENGINE CODES: Z13DTJ
HARDWARE LEVEL MAGNETTI MARELLI UNIT
MJD 603.S3 HW03A
YOUR UNIT MAY HAVE ONE OF THESE OLD PART NUMBER
55198930 CN
55568383 KZ
55568382 KY
55566039 HK
55198931 CN
So I Test it
you can change all if you have the same hw ; like in your case mjd603.
i read the org Eeprom and flash for a Corsa d and clone a other Opel number ecu with this Data . It works fine
you can clone it with Abritus AVDI org by OBD
super jumbe (20th January, 2018)
Thanks your idea noted, as I have noted on ebay there is a ECU repair service and giving lifetime warranty any one used this service and had ECU repaired successfully.
VAUXHALL CORSA D ENGINE ECU REPAIR SERVICE
https://www.ebay.co.uk/itm/vauxhall-...653&rmvSB=true
