In case my help has been useful do not forget the magic buttons. ( Thanks and * Reputation ) !!!.
ATTENTION!!!
Attempting to clean files is only to help members. By using these files, you agree to assume the consequences and are aware that all liability for any damages is entirely yours.
Thank you!
megabits.
ONLY BUT SCANNER AND CLEAR CRASH WHIT IT
vladbib (26th January, 2018)
Thanks Megabits,it works.
randewoo (20th December, 2018)
Hello guys,
Could you please help me to clear my file.
Thank you!
ATTENTION!!!
Thank you!
megabits.
vladbib (17th January, 2019)
Hi guys.
here i have file that i am not sure what is wrong with it
costumer could not verify if it crashed or not
if it have crash i need help to reset
i compared with same crashed module numbers -lot of data are have "00" in mine
the symptom i was told srs light is on
I was told -module have trouble codes for roof and seat airbag
,but module does not react to any of the other parts disconnected-no new codes shows up
i was asked to check if it crashed
here is update for problem i posted
file i posted have no crash
the problem was - missing one of the 2 fuses for SRS system
hi
place I want pass
First you should help other members, the ask about help, you are member from 2010 and nothing ...
You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
If I helped, please, use magic buttons reputation+thanks.
Best regards.
Dragon
