Page 1 of 2 12 LastLast
Results 1 to 15 of 29
    Oct 2014
    Netherlands
    Default Different VAG PQ transponders when NEC immo starts with 65 instead of 21 ?
    Hi guys,
    In very new VAG PQ cluster firmwares (for example 920 870 SW11xx) it is possible that the first byte of config in immo area is 65 (which is normally 21).
    When bit 2 (value 4) in this byte is set the cluster cannot detect a normal ID48 transponder, so it seems to check for some other type of transponder.
    Does anyone know if latest PQ VAG clusters use a different type of transponder?
    Rgs H2Deetoo
    Oct 2014
    Netherlands
    This would be the case with 2017 cars
    H.Wessel's Avatar
    Jul 2010
    I tried to program a key to a 2017 VW Caddy and I can not program a transponder, doesn't read the key.
    I tried 4 X ID48 and nothing, and this transponder are perfect because I used with others cars... So maybe you are right
    The config of this caddy was:
    2D0106220100
    Apr 2010
    Quote Originally Posted by H.Wessel View Post
    2D0106220100
    We're you able to read it like a 2016? I have been asked to do a 2017 jetta (north American so not mqb) with key from dealer but it reads like an id88 mqb key.... I haven't done it yet because I don't want to damage anything.
    If it has the same 24c64 cluster as a 2016 I can give it a try to see if it adds the dealer key but want some reassurance before risking anything
    Sent from my SM-G930W8 using Tapatalk
    H.Wessel's Avatar
    Jul 2010
    Quote Originally Posted by dmp View Post
    Yes, like 2016 read perfect, I am on Europe market, so I dont know jetta north america, but should be the same.
  6. The Following 2 Users Say Thank You to H.Wessel For This Useful Post:
    dmp (20th March, 2018), milehighlockdoc (18th July, 2019)
  7. #6
    Oct 2014
    Netherlands
    2D = 0010 1101 which means bit 2 (value 4) is set (same as 65).
    So indeed this is exactly what I'm facing as well
  8. #7
    Oct 2014
    Netherlands
    I can confirm these new transponders are ID88, the same as used by MQB clusters !
    When bit 2 is set, then the cluster only detects ID88 transponders.
    When bit 2 is cleared, then the cluster detects ID48 transponders.
    This is from SW11xx for both black/white and color.
  9. The Following 12 Users Say Thank You to H2Deetoo For This Useful Post:
    amigokola (25th November, 2018), dijo (12th November, 2019), DreamDancer (12th November, 2019), Faraday (3rd January, 2022), H.Wessel (21st March, 2018), HeXeN (21st March, 2018), jonny r (21st March, 2018), just4upal (12th December, 2021), milehighlockdoc (18th July, 2019), nazz2 (2nd December, 2022), p1et (3rd June, 2019), u.s (6th April, 2018)
  10. #8
    H.Wessel's Avatar
    Jul 2010
    Quote Originally Posted by H2Deetoo View Post
    If we clear bit 2 did you test if the cluster detects also ID88?? Or only ID48??
    ID88 is sold also in transponder format or only with remote pcb?
    I tested at this car old style remote and works fine, so remote doesn't change from 2016.
    Best regards
    H.W
  11. #9
    Oct 2014
    Netherlands
    If you clear bit 2 then ONLY ID48 is detected, ID88 will NOT be detected.
    I only found ID88 in complete key with remote.
  12. The Following 2 Users Say Thank You to H2Deetoo For This Useful Post:
    H.Wessel (22nd March, 2018), jonny r (22nd March, 2018)
  13. #10
    Dec 2009
    the wallet key for MQB Polo has glass transponder. so guess they will be available
  14. The Following 7 Users Say Thank You to exe123 For This Useful Post:
    amigokola (25th November, 2018), dmp (22nd March, 2018), H.Wessel (22nd March, 2018), H2Deetoo (22nd March, 2018), jonny r (22nd March, 2018), milehighlockdoc (18th July, 2019), p1et (29th November, 2019)
  15. #11
    Apr 2010
    I did a 2017 Jetta kessy AKL (with dealer key since I couldn't even find a source for a blank). Dash prepared like a 2016 with 24c64 eeprom. I added key on the bench (knowing I will likely have to re-add it in the car for kessy to work) in order to verify.
    Key was programmed as tested on the bench.
    Notably, when I tried to 'add key' (knowing kessy wouldn't work until I learned it), it added a chip id FFFFFFFC (not the proper ID). I had to add it with immo data to have it program to the dash properly.
    To confirm, the dash acts just like a 2016 Jetta, just requires the new chip to function.
  16. #12
    Oct 2014
    Netherlands
    id FFFFFFFC is normal when you try to read an ID88 transponder as ID48.
    So make sure you use a high enough firmware version (SW11xx) and enable ID88 transponders (set bit 2
    (value 4) as explained).
  17. #13
    Jan 2017
    Smile
    Hi all,
    I have the same problem as H. Wessel. I tried to add a Megamos ID 48 Can transponder to a 2017 NEC24C64 dashboard without success. Dashboard do not recognize transponder.
    Please could someone explain how to change the bit on the config example below ? I would like to clear bit 2, so that the cluster detects ID48 transponder as H2Deetoo wrote.
    Config: 2D0106220100
    Sorry for my question, I am an bloody beginner...
    Thanks in advance.
    re, Andi
  18. #14
    Oct 2014
    Netherlands
    2D hexadecimal = 00101101
    So clear bit 2 results in 00101001 which is 29 hexadecimal.
  19. The Following 5 Users Say Thank You to H2Deetoo For This Useful Post:
    amigokola (25th November, 2018), Andi 85 (25th November, 2018), autoTkey (16th February, 2021), milehighlockdoc (18th July, 2019), paulsta (18th July, 2019)
  20. #15
    Jan 2017
    Thanks for your answer and explanation H2Deetoo.
