Mr BLACK (22nd March, 2018)
something is not ok ....no dtc but glow plug light is flashing ..........
here you go mate please let me know
all he's maps not work and you have light on. In this ecu first use sps and up sw to new, next reset dpf. Than edit file and last ..... coding dash to without dpf. This my sugestion.
FILE SERVICE
Mr BLACK (22nd March, 2018), stanislav georgiev (22nd March, 2018)
i have no dtc with original map car was buy with no dpf and glow plug flashing with no fault code ....
standard
need to decode dpf from instrument cluster, than reset dpf again, and working soot not growing, no glow plug bulb again.
Chiptuning - Diesel / Petrol / Stage1,2,3 / HIGH Petrol Tuning
DSG TUNING
DPF / EGR / TVA / SAI / Lambda
Crackle map ( Launch Control + No lift Shift + Antilag )
File Service
PCMFLASH / BFLASH / AMT BST / AMT MPPS / TGFLASH / BITBOX / EDCSUITEPRO - Genuine USER
is it doing it as soon as you turn the car on? as soon as engine is fired 2-3 secs then flashing ? if so this sounds like turbo actuator fault. actuator arm should move when engine is started? im guessing electric actuator?
these guys know more than me I had no idea you had to decode from dash
i use pin code and i code ipc with no dpf i reset dpf in ecu ...now glow plug light is off....but i do not know for how long ...
works when you have emulated temp sensor to big value and differential apressure have value 0
FILE SERVICE
temp sensor to what value ..car have 2 sensors .. ?.....300 ..or higher 350 ...400 ?...dpf is removed from cover ...so persure must be 0
temp sensor - 350 for example
pressure - 0
than all ok.
we find also solution without decoding DPF from dash...
working like a charm.
DSG TUNING
File Service
Mr BLACK (23rd March, 2018)
a software solution ....?
