Results 1 to 6 of 6
    Nov 2009
    Above sea-level
    Default Renault Megane 2017 1.2tce shocking between 1500 and 2000rpm
    Does anyone have a solution for renault 1.2tce 132hp engine which sometimes shocks between 1500 and 2000 rpm in higher gears and especially when the engine is cold? Renault dealer has no solution but I have heard that it can be solved in the ecu software.
    Aug 2012
    Quote Originally Posted by budG60 View Post
    u will kill your waranty ?? because this problem ??? go to dealer let exchange all :-) gearbox clutch flywheel and why not engine :-)
    Tuning Cars and Trucks, Immo off , DTC delete, DPF off
    Jan 2018
    shaftesbury,Dorset,UK
    F**K That m9, take to dealers and get warranty on it, they cant con you out of a car surely?
    I'm sure if you try to write file to it. It WILL catch on fire
    Nov 2009
    Above sea-level
    Quote Originally Posted by kennyash1 View Post
    The dealer has no solution and it is not the clutch! It might be the result of lean mixture relating to emission values which should stay low. Dealer is willing to pay for solution and maintain warranty. It seems many renault 1.2tce drivers have this issue!
    Verstuurd vanaf mijn SM-G935F met Tapatalk
    Jan 2018
    hope you get it sorted mate, please keep me updated
    sdtsedat's Avatar
    Jan 2015
    Belgium
    I see you ara from Belgium or Netherlands.. go to another Renault dealer and if not ok give a complain.
    You remeber n47 timing chain problem? Bmw give warrantly if you give only complain...
    Verstuurd vanaf mijn SM-G955F met Tapatalk
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
