Hi again. My unit doesnt comunicate by diagnostic and no work. I tried to renew ee by d-flash but unit still without diag. Can anybody helps me please?
Thanks in advance
Thanks in advance
If you erase the eeprom entirely, (e.g. all bytes 0xFF), you should still have communication with the tester. You will have many problems and error codes though. (You could test that if you really want to be sure, but I highly doubt that the problem is in the eee image)
Are you sure that your programmed the eee and not the d-flash?
Maybe your P-flash is damaged. I don't have a P-flash dump for your car, but you could try programming a random P-flash image and use your own eee image. You should then be able update to the correct ZB-nr using WinKFP or ISTA/P. Any P-flash should be compatible with your eee. Of coarse, first backup your existing P-flash.
alclot (30th March, 2018)
FRM3 DUMP EEPRO
Hi inegma. You make me the same file I posted. It doesnt work ;(
Did you try re-flashing the P-flash? I don't have the exact same file but this older file should get you up and running so that you can update to latest version via OBD.
Your eeprom image should be fine.
alclot (5th April, 2018)
I just found out that there was a read error in my previous p-flash. Try this one instead (or try both and report)
alclot (7th April, 2018)
Hi mate. I tried to put your P-flash but the frm still without comunication. I finded that the amperage is less than a correct unit. Perharps when software will be ok then amperage up and comunication ok. What do you thing? Can anybody share good files same rerefence? any tip about it?
Thanks in advance
These are the my original files.
Help me please! Frm3 is completly dead. I can´t comunicate by diag. I tried with frm2 and I can comunicate and the ampers are more than frm3 dead. Can anybody help me how what I need to do please?
Thanks in advance
file ok my your
http://tlvps.tomvanleeuwen.nl/frm/convert.php
alclot (21st April, 2018)
lllllllllllllllllllllllllllllll
Hi mates,
I have same reference where all the dumps are gone less ee (original in good condition).
Can anyone help me with P-flash and D-flash read by vvdi for example please?
Thanks a lot
