Page 1 of 2 12 LastLast
Results 1 to 15 of 28
    Mar 2018
    Default Help Me Choose A Cheap Multi Use Programmer :-)
    Hi guys
    I would like to be able to clone ECU's and be able to immo some as well.
    The clone side of things seems pretty straight forward as it seems you just need to read the EEPROM of the old ecu and write it over the EEPROM of the replacement ECU.
    And there seems to be a few software packages on ebay that can remove the IMMO off the file read from the EEPROM.
    Is this all correct? ....
    Now my question is.....
    Can anyone recommend a cheap programmer that can read/write to a majority of ECU's?
    It would need to be USB and work under at least windows 7.
    I don't want to spend too much as its not something i would be using often (probably use it more for bios chips in computers).
    Aug 2015
    it is way to do some older ecu's (not even all "old" ecu types) , for newer like edc17 , pcr2.1 etc... it is not possible that way (it is much more complicated) and for some not possible at all. Anyway good and cheap all around programmer for starting and learning would be xprog and tl866
  3. The Following User Says Thank You to dtip For This Useful Post:
    Inked (9th April, 2018)
    Mar 2018
    Quote Originally Posted by dtip View Post
    Thanks for the reply.
    Two ECU's that i need to play with at the moment are one from an iveco daily that i think uses a 24c16 eeprom, and the other is a audi/vw ME7.1 or ME7.5 ecu (not sure what eeprom it uses.
    I see a lot of ecu dumps being posted on here so i though this was the normal route when it comes to ecu cloning/immo off.
    open to more suggestions
    Mar 2018
    wouldn't something cheap like this do the job:
    https://www.ebay.co.uk/itm/USB-High-...8AAOSw4GVYSBcO
  6. #5
    Apr 2010
    i think upa usb whit all adaptor is a good option. - 100 usd.
  7. The Following User Says Thank You to arielcom For This Useful Post:
    Inked (11th April, 2018)
  8. #6
    Mar 2018
    So wouldn't the one like I linked to do the job?
    It just seems very cheap and says it does 24c , 25c and 93c so should cover a lot of ecu's
  9. #7
    Jan 2016
    I do not have the experience that most people here
    but I think the willem GQ4x4 with adp019 adapter is a good option
  10. The Following User Says Thank You to chedenial For This Useful Post:
  11. #8
    Mar 2018
    Thank you
    I think I would sooner use a eeprom clip so I don't need to remove the chip from the ecu.
    Again, does anyone know if a programmer like this one would work?
    And if not can you please tell me why?
  12. #9
    Jan 2016
    I think not, because it is very limited, it only work for 24Cx 25Cx 93C
    leave out eeprom 95160, 29f400, 95p08, 95040, 95320, and many many others...
  13. #10
    Mar 2018
    Remember guys we are not looking for the best programmer here, the idea is CHEAP...
  14. #11
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by Inked View Post
    Learn first and you will fnd the best for you.
  15. The Following User Says Thank You to lion0304 For This Useful Post:
    Inked (16th August, 2018)
  16. #12
    Mar 2018
    Hi guys
    This has popped into my head again...
    Would a ktag clone be any good ?
  17. #13
    lion0304's Avatar
    Oct 2014
    Yes if you know how to operate. But it not enough.
  18. The Following User Says Thank You to lion0304 For This Useful Post:
  19. #14
    Mar 2018
    Quote Originally Posted by lion0304 View Post
    What do you mean by it's not enough?
    What else would I need?
  20. #15
    lion0304's Avatar
    Oct 2014
    Because no any tool can do all your job.
    But you can start with that
  21. The Following User Says Thank You to lion0304 For This Useful Post:
