here,
if you need immo off for eeprom let me know
Give feedback if car starts
here,
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
Djtroliz (24th January, 2019), Electro88 (21st April, 2018), Farukessss (3rd April, 2021), Yhoni (28th July, 2020)
ok thanks a lot for fast help i have read from ori eeprom gonna try and tell you if start
again thanks a lot best team forum i ever see best regards from portugal...
be careful when you try open this ecu!
its like do be dead after opened
Chiptuning - Diesel / Petrol / Stage1,2,3 / HIGH Petrol Tuning
DSG TUNING
DPF / EGR / TVA / SAI / Lambda
Crackle map ( Launch Control + No lift Shift + Antilag )
File Service
PCMFLASH / BFLASH / AMT BST / AMT MPPS / TGFLASH / BITBOX / EDCSUITEPRO - Genuine USER
mpps v12 in recovery with ori sometimes can save some edc16 ecus
which tool is used when is failied ?
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
sdtsedat ty again car already run fine but now have esp light on engine light on and errors P1617 P2239 if someone know ....many thanks to all ....
ok the problem is hw/sw from the file is old the ecu from car is SW1037375678 HW1037375678 so i try one from another ecu not same ref but same car whit HW1037376896 SW1037376896 now is ok no errors the file in use is..
Ty all for support
Djtroliz (24th January, 2019), khaleddaddi (4th May, 2021), Yhoni (28th July, 2020)
Hi, there, l have the same problem hith a EDC16c2/7, A6461538179, when l tryd to write with Galleto4, was locked, now, only the fan working... wich is the solution?
Thanks in advance!
The problem is the trolls
Hello, I have a W203 c220 611 vehicle. I need Egr off and stage 1 software. Can you help me? Thank you so much
