Page 1 of 2 12 LastLast
Results 1 to 15 of 28
    richiebb's Avatar
    Aug 2015
    Argentina
    Default Introduction to HPL Scripts for orange5 - DashBoard. educational purpose
    some time ago I started to make some script for orange5, I know that many of you here know how to make them ................ for those who do not, here goes......
    ; Clio Mio Magneti Marelli / Sandero with 95020 tested in 2014 models
    ; comments for this sample script is based in 41200km
    ;................................................. 41200 * 1000 = 41200000 ---------------------------------------
    ;.................................................41200000 toHex = 02 74 A9 80 ----------------------------------
    ;.................................................02 74 A9 80 Swap = 80 a9 74 02 --------------------------------
    ;.................................................first 4 bytes 80 A9 74 02 ---------------------------------------
    ;.................................................80 A9 74 02 xor FF FF FF FF = 7F 56 8B FD (last four Bytes) -----
    ClioMio.hpl
    [!#"Old KM"]
    ADR=192;..................Set in position 192 decimal = hex 0x0c0
    R6=1;.....................Put 1 in Registry R6
    LOOP=(0,63){;.............Start a Loop 64 cycles
    MARK=R6;..................Mark Current Position
    ADR=+1;...................Increment in 1 Address
    };........................end of loop
    ADR=195;..................Set in position 195 decimal = 0x0c3
    R6=DATA;..................Stored Current data Buffer(0x0c3) in Registry R6
    ADR=-1;...................decrement in 1 Address
    R7=DATA;..................Stored Current data Buffer(0x0c2) in Registry R7
    R8=DATA;..................Stored Current data Buffer(0x0c1) in Registry R8
    R9=DATA;..................Stored Current data Buffer(0x0c0) in Registry R9, asume for this sample 0x080
    R6=<<24;..................move 6 nibble to left R6 Value. Sample R6 vale are 0x002 after move: 0x02000000
    R7=<<16;..................move 4 nibble to left R7 Value. Sample R7 vale are 0x074 after move: 0x00740000
    R8=<<8;...................move 2 nibble to left R8 Value. Sample R8 vale are 0x0a9 after move: 0x0000A900
    R8=+R6;...................sum R8 Value to R6.....0x0000A900 + 0x02000000 = 0x0200A900
    R8=+R7;...................sum R8 Value to R7.....0x0200A900 + 0x00740000 = 0x0274A900
    R8=+R9;...................sum R8 Value to R9.....0x0274A900 + 0x00000080 = 0x0274A980
    R8=/1000;.................divide by decimal 1000 R8 value....... 0x0274A980 / 1000 = 0x0A0F0
    PRINT=("Current Mileage = %06lu km.",R8);..Print Rezult
    [!#"New KM"]
    R4=0;.....................Put 0 in Registry R6
    GET=("Enter New KM",R4);..open Dialog Box and Request New Mileage end stored in R4...asume for this example 41200km
    R4=*1000;.................multiply R4 registry by 1000 ......R4 * 1000 = 41200000
    R9=1;.....................Put 1 in Registry R9
    R3=R4;....................Stored Value enter in GET=("Enter New KM",R4) in R3 registry (41200000)=(0x0274A980)
    R5=R4;....................Stored Value enter in GET=("Enter New KM",R4) in R5 registry (41200000)=(0x0274A980)
    R6=R4;....................Stored Value enter in GET=("Enter New KM",R4) in R6 registry (41200000)=(0x0274A980)
    R3=&000000FFH;............make a AND Logical R3 by 0x0ff....... 0x0274A980 AND 0x000000FF = 0x00000080
    R4=&0000FF00H;............make a AND Logical R4 by 0x0ff00..... 0x0274A980 AND 0x0000FF00 = 0x0000A900
    R5=&000FF0000H;...........make a AND Logical R5 by 0x0ff0000... 0x0274A980 AND 0x00FF0000 = 0x00740000
    R6=&0FF000000H;...........make a AND Logical R6 by 0x0ff000000. 0x0274A980 AND 0xFF000000 = 0x02000000
    R4=>>8;...................move to right 2 nibble...0x0000A900 to 0x000000A9
    R5=>>16;..................move to right 4 nibble...0x00740000 to 0x00000074
    R6=>>24;..................move to right 6 nibble...0x02000000 to 0x00000002
    LOOP=(0,7){;..............Start a Loop 8 cycles
    DATA=R3;..................set Value 0x00000080 (80) in current Position
    MARK=R9;..................Markcurrent position
    ADR=+1;...................Increment in 1 address
    DATA=R4;..................set Value 0x000000A9 (A9) in current Position
    DATA=R5;..................set Value 0x00000074 (74) in current Position
    MARK=R9;..................Mark postion 194(c2)
    DATA=R6;..................set Value 0x00000002 (02) in current Position
    ADR=+5;...................Increment in 5 address
    R3=^0FFH;.................R3 xor 0xff....0x00000080 xor 0x000000ff = 7F
    R4=^0FFH;.................R4 xor 0xff....0x000000A9 xor 0x000000ff = 56
    R5=^0FFH;.................R5 xor 0xff....0x00000074 xor 0x000000ff = 8B
    R6=^0FFH;.................R6 xor 0xff....0x00000002 xor 0x000000ff = FD
    ADR=196;..................Set in position 196 decimal = hex 0x0c4
    DATA=R3;..................set Value 0x0000007F (7F) in current Position
    DATA=R4;..................set Value 0x00000056 (56) in current Position
    DATA=R5;..................set Value 0x0000008B (8B) in current Position
    DATA=R6;..................set Value 0x00000080 (FD) in current Position
    leave HPL file in attachment
    for see in type menu......... must to add to CFG File:
    Sample:
    GROUP=Renault ; if not exist
    CHIP=Clio Mio / Sandero 95020,256x8,"HPL_ROOT_DIRECTORY"\ClioMio.hpl
    Questions and Request made here: Question and Request for HPL Orange5 Scripts
  2. The Following 17 Users Say Thank You to richiebb For This Useful Post:
    automotrizVIP (23rd April, 2018), bandus (2nd June, 2018), Catalizator (29th January, 2019), ceregarak (17th May, 2018), claudio35 (24th April, 2018), Diagcar1 (18th June, 2018), dorofteius (18th June, 2018), Dr. Zoidberg (23rd April, 2018), gepakg (21st January, 2019), jomberykaso (23rd April, 2018), ledong (25th April, 2018), lwd11 (15th May, 2018), Meat-Head (11th November, 2019), melectro (26th May, 2018), mikroel (23rd April, 2018), Shokunin (11th May, 2018), talk2idris (24th April, 2018)
  3. #2
    richiebb's Avatar
    Aug 2015
    Argentina
    Default algo for BSI Siemens Peugeot 207
    I leave the algorithm for a BSI siemens E02-00 of peugeot 207 year 2013 that I did today, .........when I can........i do the script!
    Tested en Peugeot 207 year 2013
    KM * 10 -> XOR FFFFFF -> BYTES SWAP = KM 3 BYTES [0]xx [1]xx [2]xx
    KM BYTE for calc CS[0] = add FF to left... sample FFxx
    KM BYTE for calc CS[1] = add FF to left... sample FFxx
    KM BYTE for calc CS[2] = add FF to left... sample FFxx
    checksum 1 0x12B= 0x12F + 0x130 + KM BYTE for CS[0] + KM BYTE for CS[1] + KM BYTE for CS[2] - 1FD AND FF
    checksum 2 0x131= checksum 1 - (0x12A - 0x130)
    *NOTE: addresses are in format 0x00, values are in format 00
    Lines 120 and 130 for this sample, with 75000km
    0x120: 1F FF F9 37 6B F7 FC FA FB FF 49 1D 4F 8E F4 FF
    0x130: 4A1E 4F 8E F4 FF 7C C0 DE 64 EB FF AB 5C FD FF
    sample 75000km
    75000 * 10 = 750000
    750000 toHex= 0B 71 B0
    0B 71 B0 xor FFFFFF = F4 8E 4F
    F4 8E 4F swap = 4F 8E F4
    4F 8E F4 (km bytes) 0x12c=4F,0x12d=8E,0x12e=F4,0x132=4F,0x133=8E,0x134=F4
    checksum 1 0x12B= FF + 4A + FF4F + FF8E + FFF4 = 3001A
    3001A - 1FD = 2FE1D
    2FE1D AND FF = 1D
    checksum 2 0x131= 49 - 4A = -1
    1D - -1 = 1E
    address km in lines 0x120 and 0x130
    0x120: XX XX XX XX XX XX XX XX XX XX XX 1D 4F 8E F4 XX
    0x130: XX 1E 4F 8E F4 XX XX XX XX XX XX XX XX XX XX XX
  4. The Following 10 Users Say Thank You to richiebb For This Useful Post:
    automotrizVIP (15th June, 2018), claudio35 (16th June, 2018), dorofteius (18th June, 2018), Dr. Zoidberg (15th June, 2018), fuktak (18th July, 2018), marius7592 (21st November, 2018), perfido (17th June, 2018), SergeyIg (10th August, 2018), stoyanov (11th December, 2018), XJTAG (17th October, 2019)
  5. #3
    richiebb's Avatar
    Aug 2015
    Argentina
    continuing with the previous post ......... I leave the script for BSI siemens E02-00 of peugeot 207 year 2013
    ; CHIP=25c160 (2048x8) SPI
    HPL=25c256.hpl
    POWER=0
    R0="New KM",D;................................Set R0 Registry as Decimal for input dialog
    [!#"KM"]
    ADR=0x131;....................................set address in hex 131
    LOOP=(0,3){;..................................start a loop of 4 cycles
    MARK=1;.......................................put mark in current position
    ADR=+1;.......................................increments address in 1
    };............................................end of loop
    ADR=+2;.......................................increments address in 2 hex 133
    };.............................................end of loop
    ADR=-7;.......................................decrements address in 7 hex 12c
    R4=DATA;..........................................store current data in R4 registry
    ADR=-1;.......................................decrements address in 1 hex 12b
    R5=DATA;......................................store current data in R5 registry
    ADR=-1;.......................................decrements address in 1 hex 12a
    R6=DATA;......................................store current data in R6 registry
    R8=0FFFFFFH;..................................assigns to R8 registry value hex FFFFFF
    R4=<<16;......................................move four nibble to left R4 registry
    R5=<<8;.......................................move two nibble to left R5 registry
    R4=+R6;.......................................add R6 to R4
    R4=+R5;.......................................add R5 to R4
    R4=^R8;.......................................xor R4 to R8
    R4=/10;.......................................divide R4 by 10
    PRINT=("Current KM: %06lu km.",R4);...........PRINT R4 in decimal format "%06lu" fill six 0 to left
    [!#"New KM"]
    R0=0;.........................................assigns to R0 registry value hex 0
    GET=("New Km",R0);............................Open a input dialog and store in registry R0(decimal)
    R0?<100{;.....................................if R0 is minor to 100 then executed code between {}
    PRINT=A("No less than 100 km!");..............print a warning
    EXIT;.........................................exit - no more lines are executed
    };............................................end if
    R0=*10;.......................................multiply by R0 Registry
    R8=0FFFFH;....................................assigns to R8 registry value hex FFFF
    R5=R0;........................................assigns to R5 registry R0
    R6=R0;........................................assigns to R6 registry R0
    R9=255;.......................................assigns to R9 registry value decimal 255
    R5=&00FF0000H;................................make a logical AND to get XX---- value
    R5=>>16;......................................move to right 4 nibble
    R6=&00F0FF00H;................................make a logical AND to get X-XX-- value
    R6=>>8;.......................................move to right 2 nibble
    R0=&00F000FFH;................................make a logical AND to get ----XX value
    R0=^R8;.......................................xor R0 to R8
    R6=^R8;.......................................xor R6 to R8
    R5=^R8;.......................................xor R5 to R8
    R8=R0;........................................assigns to R8 registry R0
    R8=+R6;.......................................add R6 to R8
    R8=+R5;.......................................add R5 to R8
    ADR=012FH;....................................set address in hex 12F
    R2=0;.........................................set R2 to 0
    LOOP=(0,1){;..................................start a loop of 2 cycles
    R3=DATA;......................................store data in R3
    R2=+R3;.......................................add R3 to R2
    R8=+R2;.......................................add R2 to R8
    R8=-01FDH;....................................subtract 1FD to R8
    R8=&000FFH;...................................make a logical AND to get ----XX value
    R9=R8;........................................assigns to R9 registry R8
    ADR=-7;.......................................move cursor to address 12A
    R1=DATA;......................................store data in R1
    ADR=+6;.......................................move cursor to address 130
    R2=DATA;......................................store data in R2
    R1=-R2;.......................................subtract R2 to R1
    R9=-R1;.......................................subtract R1 to R9
    ADR=-5;.......................................move cursor to address 12B
    DATA=R8;......................................change CS 1 data
    MARK=1;.......................................mark position
    DATA=R0;......................................change KM byte[0]
    DATA=R6;......................................change KM byte[1]
    DATA=R5;......................................change KM byte[2]
    ADR=+3;.......................................increments address in 3
    DATA=R9;......................................change CS 2 data
    GROUP=Peugeot; if not exist
    CHIP=206/7 BSI Siemens 95160,2Kx8,Dash/206BSI7.hpl; assuming that in the folder of the HPL directory the folder for the dashboard is called "Dash"
  6. The Following 4 Users Say Thank You to richiebb For This Useful Post:
    claudio35 (19th June, 2018), Diagcar1 (18th June, 2018), dorofteius (18th June, 2018), marius7592 (21st November, 2018)
  7. #4
    Jan 2010
    Trstenik - Thun
    can you explain,or give calculating , on this example, how to calculate PIN code from this file
    Real pin code is 4362
    in the file pin showed as 4326
  8. The Following User Says Thank You to mikroel For This Useful Post:
  9. #5
    Dr. Zoidberg's Avatar
    Oct 2015
    Talca-Chile.
    4326 Is ASCII---
  10. #6
    Jan 2010
    Trstenik - Thun
    yes 4326 in ASCII , so?
  11. #7
    Oct 2015
    Talca-Chile.
    Quote Originally Posted by mikroel View Post
    Now, look again your file.....
  12. #8
    Jan 2010
    Trstenik - Thun
    You didn't understand me well,
    or i didn't explain well
    i already showed on my photo (RED square) where is pin in HEX and in ASCII and which one is Real PIN CODE
    I asked how to make procedure in calcs for read PIN code from this location
  13. #9
    richiebb's Avatar
    Aug 2015
    Argentina
    Hi. look this
  14. #10
    richiebb's Avatar
    Aug 2015
    Argentina
    ; read PIN Code
    @ART=4
    ["!#READ PIN"]
    ADR=0x1e6
    LOOP(4){
    R0=DATA
    @ART[I]=R0
    ADR=+1
    PRINT=("Pin code is %s",@ART)
  15. #11
    Jan 2010
    Trstenik - Thun
    hanks friend
    but result is
  16. #12
    richiebb's Avatar
    Aug 2015
    Argentina
    I just tried and the script works well.
    I was guided by the photo of your post and begins to read the ascii in the address 0x1e6.
    put a mark to see if you have the address well
    ; read PIN Code
    @ART=4
    ["!#READ PIN"]
    ADR=0x1e6
    LOOP(4){
    R0=DATA
    @ART[I]=R0,MARK=1
    ADR=+1
  17. The Following User Says Thank You to richiebb For This Useful Post:
    dodge69 (31st May, 2019)
  18. #13
    richiebb's Avatar
    Aug 2015
    Argentina
    16bits eeprom script
    ; read PIN Code
    HPL=93c66.hpl
    @PIN=4
    ["!#READ PIN"]
    ADR=0x0f3
    R0=DATA,R1=R0
    R0=&0FF00H,R0=>>8
    R1=&0FFH
    ADR=+1
    R2=DATA,R3=R2
    R2=&0FF00H,R2=>>8
    R3=&0FFH
    @PIN[0]=R0,@PIN[1]=R1,@PIN[3]=R2,@PIN[2]=R3
    PRINT=("Pin code is %s",@PIN)
  19. The Following User Says Thank You to richiebb For This Useful Post:
    mikroel (22nd January, 2019)
  20. #14
    Jan 2010
    Trstenik - Thun
    last one working good
    note:
    vectra c has several different version of clusters as well dumps ,so universal dash calculator is very difficult to make
  21. #15
    Dec 2018
    for renault have more script?
